CLICKING NOISE UNDER DASHBOARD CLK 500 2004
Old Apr 28, 2017 | 07:54 AM
mercedes3015's Avatar
CLK 500 2004 SEDAN
Hi, I need help to find out what is a clicking noise, something like a relay that started recently under the dashboard of my CLK 500 2004.
It starts after I shut off the engine and last like 10 or 15 seconds making the clicking noise then stops until the next time I stop the engine.
The A/C on or off did not make any difference. The only work done recently was adding some freon R134 to the A/C.
The car and the A/C run OK othrtwise.
Any sugestions or method to trouble shoot this ?
Thanks in advance
Old May 1, 2017 | 05:41 PM
91ser's Avatar
2003 CLK500, 2003 CLK55, 2008 CLK550
If its the typical clicking, its from the vent motors. Its a pretty common problem on the early CLKs. There is a method of trying to reset them that I believe has fixed the problem for some people. Most I believe end up replacing it tho. Im sure there are some threads on the problem, but Ill have to look later. Leaving work now! HAHA
Old May 3, 2017 | 02:22 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I heard this a couple of times but I have a yard full of trees and a leaf sometimes gets into the wrong place.
On another note: heard a Humming on one of my other cars under the hood. Started unplugging relays and fuses until the noise went away. just a hunch.
Cheers
Old May 3, 2017 | 09:35 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
It's usually the linkage arm for one of the flap motors. The plastic linkage cracks and the click is it skipping on the motor shaft (hex drive). I've done a few dozen but for a first timer you'd probably be better off having a pro at your local dealer do it. You could end up breaking things on disassembly and it'll take you 10x as long. The part is real cheap, probably 3 hours or so labor.
Old Sep 4, 2017 | 01:11 PM
san-antonio's Avatar
Merc CLK 55 AMG
Hi,
does it sound like this?
Started this morning on my CLK500:
Thanks in advance
