W209 CLK55 Headlights.
Any W209 owners have problems with the headlight position? My driver side headlight does not light up the road in fornt of me at all. The beam is alos lower than the pasesenger side. I can barely drive my car at night because of the lights. A 04 E320 that I drove had an amazing light beam, the road visibility was very good. MB said they adjusted the lights to factory spec but they look the same to me.
Any help would be appreciated Johnny |
Dude, I feel your pain. You described my headlights exactly!!
The low beams are horrendous. Its to the point that I'm forced to slow down when using my low beams because I start to focus on the line that is formed by the lights and the darkness and I can't tell whats coming up. It sucks. Thank God the high beams are super strong! After this winter I will bring her in for my first service. I will have them check the lights out. I have read in other posts that this is the way Mercedes sets the lights from the factory as not to blind oncoming traffic. The driver side headlight shines about a foot lower on the road than the other. This sounds retarded to me, but I'm afraid my dealership probably won't help much. I thought I also read somewhere that you can adjust these headlights yourself. When you pop the hood, isn't there a spot where you can turn a screw or something and it raises the lights? Let me know if anyone finds this? |
i know this probably won't help but since i'm not in front of my manual or car, all i know is that on the BMWs there is a screw (which is really two little gear thingies) that you use a phillips on and it moves the HID beams higher/lower whatever.
I have an '04 CLK500 and agree that the driver HID beam is slightly lower than the right side. i also agree the beams are not as bright as my prior BMW 3 series HID. but they are definitely fine enough to drive w/o problems on low beam. High beam is devastatingly bright - lights up miles away! |
You can adjust the height manually. But maybe there is something wrong with the auto leveling sensor????
greetingz, |
I have the Bi-Xenons and I have seen the auto-leveling mechanism in action......but my car has always been like this. Its not something that just happened one day. So I am ruling out the leveling sensor. I think MB did that on purpose...as not to blind oncoming traffic.
I had the same problem. I took it to my dealer and they adjusted them up for me and now they are fine. The were really low especially on the driver side.
I check to see if I can adjust them up alittle.
Harris, Maybe the 2" drop that the Carlsson RS suspension gave me is causing the beam level to be lower than the factory setting. I've also never seen the auto levelling mechanism work and I have the Bi Xenons. Johnny |
Harris, Maybe the 2" drop that the Carlsson RS suspension gave me is causing the beam level to be lower than the factory setting. I've also never seen the auto levelling mechanism work and I have the Bi Xenons. Johnny I have the same drop as yours and I have no problem with the lights. Btw, I've received the "Purolator envelope" and I am arranging for a shipping company to pick up the parts. Since it is such a huge box traveling for such a long distance, I just want to make sure the company is reliable. |
Cool Thanks,
Now should I go ahead with the LSD or what!!! |
The sensor is mounted on the front sway bar.
greetingz, |
Cool Thanks,
Originally Posted by Stiggs
I'm gonna have to guess you're not talking about the street drug here?
You should get one for your car. |
What does it do for you?
Originally Posted by oracledba
for me i used to see all this wierd stuff and colors. i had a really bad time at Disneyland one time on spring break after i mixed blotter and chocolate donuts
:crazy: |
