Build the most powerful cls550 4matic
Rating: Thread Rating: 2 votes, 5.00 average.
Old 05-15-2016, 04:10 PM
gardevski's Avatar
cls63 amg pp 700hp, ml63 amg w166 700hp, cls550 4matic 720hp
Hi Guys,
As the thread title say i'am about to share my cls500 2013 build with you. For those of you that want power the thread will be very informative. Target 700-750+hp from m278 engine
Will share all part numbers and parts needed for the upgrade.
So far my upgrades are:
E63 amg s intercooler pump with additional IC raciator
IC separated from the main water circuit (part numbers for the upgrades will be provided)
Alpina b7 spark plug (one step colder)
K&N air filter with lifted air boxes upgrade for more flow
M157 turbochargers (left and right)
63 amg air intake
3 inch turbo-back to muffler exhaust system with 100 cell cats
63 amg ecu maps
Currently my engine is out for the turbo upgrade and exhaust (SS 3 inch turbo-back downpipes, H-pipe straight 3 inch mufflers) setup. Once the car is fully complete will share the result with lots of pictures and dyno run.
Before the turbo upgrade the car did 542HP / 1100NM 0-100km/h 3.8-4sec 100-200 8.3-8.6 sec
Will post more info next week after the turbo and exhaust upgrade.
Hope my thread will help other looking for sleeper car.
M157 Turbochargers
The following 3 users liked this post by gardevski:
gqambitions (06-03-2016), jahquan3 (05-15-2016), JeanPierPapin (12-28-2020)
Old 05-15-2016, 04:53 PM
yoyo7112's Avatar
2012 CL550
Hi
Nice upgrde
I have M278 CL550 do you have part # for Alpina b7 spark plug (one step colder) ???
Old 05-15-2016, 05:00 PM
gardevski's Avatar
Will check and let you know. The plugs run great after heavy upgrades..
Originally Posted by yoyo7112
Hi
Nice upgrde
Old 05-16-2016, 06:13 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
awesome!!! lets see some numbers after all these upgrades.
Old 05-17-2016, 07:05 AM
gardevski's Avatar
The Alpina B7 spark plugs (one step colder than the M278/m157 factory plugs):
NGK SIZKBR8A8HS
Hi
Nice upgrde
GT532 (05-29-2020)
Old 05-17-2016, 11:22 PM
scflaw's Avatar
W218 CLS 400, F20 M135
I'm very interested in how you got the pump to work. Is the V8 water to air cooled? Also what extent did you have to go through to get the modifications to workwork. Thanks!
Old 05-25-2016, 11:23 PM
TTMerc's Avatar
2014 CLS63 S
Following this build for sure. Finally someone tearing in to the M278 platform. Should produce well. I am also pursuing large gains but going a different route with mine. My car is a Base P1 so will be a bit lighter but also traction hindered a bit till the diff and tires go on! Cant wait to see your results!!
Old 05-27-2016, 03:48 PM
mJstk01's Avatar
In... look forward to updates
Old 05-31-2016, 04:44 PM
mJstk01's Avatar
Was the 700-750hp target based on the current upgrades you were installing now or do you have other plans?
As I understand, CLS63 w/ tune has about 650 to 700hp at the crank.
It will be interesting to see what the M278 makes w/ M157 turbos and tune.
Old 05-31-2016, 07:12 PM
Deezbluballz's Avatar
2012 E550
Nice Project! In for updates.
Old 05-31-2016, 07:44 PM
DATURK's Avatar
2010 HARLEY FLHTK, 2013 SL550, 2014 S63
very interesting....
Old 06-01-2016, 02:44 PM
gardevski's Avatar
The limiting factor here are the M157 turbo chargers. Iám installing the M157 turbos next week as i was busy with the exhaust (3 inch from the turbo outlets all the way to the mufflers ) The M278 engine has same exhaust valves as the M157 so no problem for 700hp+ with the right ecu tune. You need same boost and fuel to match the M157. Will see after the dyno. The guys who will make the ecu made 801hp crank e63amg s with the same turbos. Also i can confirm that after 6k miles with 1100NM my gearbox is shifting as when it was new.
Will provide full part list after the upgrade is completed.
Old 06-08-2016, 12:15 PM
TTMerc's Avatar
2014 CLS63 S
Going with the new colder plug, have you gotten a chance to confirm the correct indexing or did you index them yourself? Any side by side pics?
Thanks!
Old 06-13-2016, 11:44 AM
mJstk01's Avatar
Any luck on this project?
Old 06-13-2016, 03:13 PM
gardevski's Avatar
Waiting for the m157 torbochargers to be installed. Once all is complete will provide the result with full details on the mods, parts needed and dyno results.
Old 06-14-2016, 12:07 PM
DATURK's Avatar
I'm no expert but I been told that AMG vs non AMG engine blocks same however some of the components on AMG like pistons, crank, piston arms...etc are stronger to hold the power, by you replacing all the components you are referring, is the engine gonna hold all that power, are you not gonna jeopardize anything...besides that I can't wait to see your results...
Old 06-14-2016, 03:00 PM
gardevski's Avatar
The m278 engine feature forged pistons , connecting rods (same part number as M157 engine) and forged crankshaft. I'am sure that m5 f10 or RS6-7 engines are not much stronger than the M278 engine but feature larger turbocharges and better cooling. Will see when the car is ready
Old 06-14-2016, 08:34 PM
DATURK's Avatar
are you plan on upgrading the m157 turbos for bigger spool? or are you gonna leave as factory m157?
Old 06-15-2016, 03:07 AM
scflaw's Avatar
I've been researching and they say the e63s coolant pump is the same as the other Benz's which have an water to air intercooler. Is that true? Thanks
Old 06-15-2016, 03:40 AM
BlownS4's Avatar
2015 E63 - Current, 2012 E550 - Current, 2019 Audi Q7 3.0T - current
I don't think so because their are two tuners and our friend Gardevski here who have changed to the E63 pump.
AMS sells a cooling solution.
SpeedDriven sells the E63 pump as an upgrade.
Old 06-15-2016, 01:21 PM
BlownS4's Avatar
dyno
Hey Gardevski can you repost your Dyno the link in the original thread is broken. Also did you get a dyno sheet you can post as well?
Old 06-16-2016, 01:32 AM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
I got some weistec m157 turbos for sale if anyone is interested,also have Ams cooling system and Ams carbon intake and weistec downpipes n midpipe for a rwd w212
E550V8 (10-23-2019)
Old 06-16-2016, 02:38 AM
BlownS4's Avatar
how much you asking for the cooling system?
Old 06-16-2016, 08:23 AM
gzim335's Avatar
Looking for $1500 Obo
Old 06-26-2016, 11:54 AM
mJstk01's Avatar
What's the latest?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Build the most powerful cls550 4matic
