Heavy metallic knocking sound from Engine
CLS550 4Matic W218
Hi guys,
Since Summer I got a heavy metallic knocking sound from the left cylinder bank on the engine. (M278, Biturbo V8)
Car was already by MB Dealer for checking - they seemed to be surprised by this noise and had absolutely no idea - but - already wanted to tear down the whole engine for a fortune.
The metallic knocking is especially from inside the cabin very loud and can be notices under acceleration - on the freeway at about 80 there's no sound anymore.
Info:
Engine oil was flushed twice since summer - once 5W-40 and testwise a 15W-60.
Felt also to give Lucas Oil Stabilizer into the engine - no dampening or change of sound.
Compression on all cylinders is good - power delivery is also good - no lack of power.
I attached a video from someone with the same problem.
Would be nice if there are some good answers to this problem. It drives me crazy. Even don't want to move the car anymore.
Thank you
Info:
Thank you
What was the result of this noise? We have a GL63 with same noise.
Hi guys,
Info:
https://www.youtube.com/watch?v=WXRWXa_j0qI
Thank you
Info:
Thank you
Piston skirts are short for fuel economy. Less drag within the rotating assembly. Mercedes has designed these 157 and 278's to be 200,000km engines.
Incorrect, this engine is completely bulletproof - it was in the (2010+) GL550, S550, SL550, G550, E550 and CLS550 among other models and there have been no reports of this (piston issues) or it would be ALL over the forum.
That's why I am curious as to what this is or how this failure occurred. I imagine it was a timing chain slippage, abused engine or one off and bad from the factory. What are others thoughts on this?
You are correct in stating your E550 engine and the 2010 engines are reliable as they are a different engine.
With all due respect sir, are you a Mercedes mechanic? Today alone, I spoke with 3 techs from the team leader to the manager of maintenance (who I know personally). Their privately owned dealership has not seen even one engine failure of any M278 (G, SL, S, E, CLS, GL class) bi turbo engine aside from some issues with timing chain issues with the earlier models and also fuel injectors.
I also cannot find one other post other then this one with a M278 engine with failure due to piston play issues. There are common issues with oil cooler, oil leaks, valve cover, front diff seal leaks, timing chain (again early 2011 models), fuel injectors (again early models) and some other problems but not one report, post of an engine failure due to a piston. These engines/motors and vehicles are now exceeding 8+ years old of various models with some (300,000KM+) now in forums/databases.
The AMG's (M157) have problems that I see all over various forums and even MB techs I talk to. They have timing chain, valve, early camshaft wear, headgasket, piston and other various problems but the M278 seems pretty bullet proof. I'm going to have to call you out on this and ask to provide some proof.
dark_cls550 (11-17-2020)
Yes dealer tech from May 2008 until 2019. What part of the world are you in? We have had 3 now at the dealer and 1 including my own vehicle. No need to get upset. But the days of the bomb proof engines are gone unfortunately.
Good example would be the 642 engines. We again have issues where I am. But talk to the guys in the southern states, they have a fraction of the failures we have. Driving style, location, ambient temp how the engine is loaded upon commutes all are taken into account.
Thanks for your quick replies because this information is quite useful and I am now "second guessing" my purchase if what you are saying is in fact correct and you were a dealer certified tech which it sounds like, you were. I own a 2014 CLS550 now 4 matic.
I am from Oakville area. So what you're saying is this a ticking time bomb, could last 350,000 or 35,000KM? You saw 3 failures at your dealer? What mileage? What models?
Thanks man.
Thanks man.
TripleC (05-23-2021)
Just remember, being a dealer tech and now specializing, I will always have a MB product in the driveway regardless of its reputation or issues.
What vehicle did you end up buying?
Ghostty (11-17-2020)
Hi, I have to writte a litlle bit about these engines..I am from europe(czech republic) and we have many discussions about engines M157 and M278.
Unfortunately there is a problem with them and so far I had not found what is the main reason, that car, which cost over 100 000 euros, has inside the engine after 100 000km someting like in the picture below.
cylinder
Piston
cylinder
Piston
There is maybe problem with oil lenght interval, which is here 25 000 km or one year..I think 10 000 km is maximum for oil.These engines are in summer really hot, and
because over here many people are driving in high speeds, it may cause the engine is worned out.For myself I have CLS 500 shooting break, which has M278 engine,
so far no problems, but I am trying to find as much informations as possible to prevent engine failure. For another problem-time chaine, check out this page, it will tell you, if you have
new time chaine or old one:
(2:40 min in video)...thig guy-he has shop in SAE, he has a lots of videos of M278 or M157 to be repaired...in SAE is really hot, cheap gas and people are driving full throtlle all the time
Sorry for my english, I hope you understand me well
cls550_inparadi (10-02-2021)
Actually some guy mentioned in the video that it could be the dual-mass flywheel
That is entirely possible and woudl be fairly easy to hear if you were under the car, with maybe a stethoscope or whatever to isolate the noise to the flywheel area. Only way to know would be to pull the trans sadly but might be worth it if you are embarking on an engine rebuild
That is interesting. I would also check engine oil again. Like drained and filled to specs. Not siphoned or checked with a dipstick. I found that the dipstick indicates to high or too low depending on the temperature, and I believe a wrong oil level may cause that sound. Just throwing some ideas out there.
To check the cylinder scoring a bore scope through the spark plug is likely useful before a tear down. Interesting discussion re flywheel.
Hello everyone, yes this was the issue. Heavily scored cylinder walls - requiring engine replacement. We have replaced 3 of these engines since this post. Very unfortunate. Please change your oil everyone, and buyer beware without a scope of the cylinder walls prior to purchase.
cls5504matic (01-22-2021)
Thanks man.
Thanks man.
Dude I as well own a 2013 CLS550 4matic and iam having a ticking sound coming from the central area of the engine below the heat exchanger inter cooler area.
I will be investigating the cylinders with a Bore Scope & determine if the ticking is a cylinder failure or Bottom end issue.
So far there is no Miss Fire or engine light. Power seems to be there under heavy driving.
Very strange that it has a significant ticking sound but doesn't seem to show any symptoms of an engine failure
My engine bay setup!
Metallic noise
Hi guys,
Info:
Thank you
Info:
Thank you
my advice for people like me love to keep cars for a long period even to store not sell. Dont buy these engine u will be disappionted and hate mercedes .
Metallic noise
Hi guys,
Info:
Thank you
Info:
Thank you
my advice for people like me who like to keep cars for a long period even to store not sell. Dont buy these engine u will be disappionted and hate mercedes for sure.
This is totally correct there is an issue in tgese engine piston all these engine will go bad at some point not far from 200k km. I have this problem at 80k km and mercedes told me i have to change the engine which unfotunalty cost more than the car .
