Anyone tried this OBD2 Lowering Module?
Old 03-31-2018, 07:08 PM
  #51
Clkboi's Avatar
CLS550 4Matic
Originally Posted by rrsupercharged
I plugged it in and got into the factory height menu but could not get out of it. I have the 2012 w218. I don't have the touch pad but was assured by the seller it will work with my vehicle. I've tried everything from turning the dial, clicking it left,right, up,down, using the buttons on my steering wheel and it's just stuck on the initial factory height menu. I emailed the seller...just waiting for a reply.
Use the radio command buttons!
Numbers 4 and 6
Numbers 2 and 8
Old 04-01-2018, 04:11 AM
  #52
rrsupercharged's Avatar
RRS Supercharged and CLS550 (W218)
Ok...I didn't realize the instructions were in the bottom of the description part of the sales page. I played with it a little and the unit works as advertised. VR gave a great description of how the unit works so I won't repeat what was already said. Well worth the money.
Old 04-01-2018, 08:02 AM
  #53
Ariesfamous's Avatar
2015 cls550
Good to hear.
How about a pic or two?!
Old 04-04-2018, 04:03 AM
  #54
Tony Salib's Avatar
E Class W212 E500
Check out this video where he explains how to do it on cars without the touch pad:
Old 04-11-2018, 02:36 PM
  #55
Exup99's Avatar
E350T Bluetec
I'm tempted on trying on my 2014 W212 Wagon...
Any of you guys can give me a bit of feedback about the loss of ride quality when lowering the car?
My idea is just to lower a little bit (1 finger +-).
thanks in advance
Old 04-11-2018, 03:12 PM
  #56
Gasmiser2000's Avatar
E350 estate, Audi S4, BMW F800R
My idea is just to lower a little bit (1 finger +/-)
Are you just planning to lower the back, I was under the impression only the rears had adjustable air suspension
Old 04-11-2018, 03:52 PM
  #57
Exup99's Avatar
E350T Bluetec
On all S212 (W212 Wagon) as standard comes with air suspension (to keep it leveled when some weight is added), but as an option can come equipped with full Airmatic with adjustable suspension (Confort, Sport and Raised settings).
Mine come with the Airmatic on all corners, so with this module I should lower front and rear as desired. (hopefully :-))
Gasmiser2000 (04-11-2018)
Old 04-11-2018, 04:37 PM
  #58
VirtualRain's Avatar
2016 CLS550 4Matic
thanks in advance
I don’t think lowering affects the ride quality that much. At least I didn’t notice anything that stood out from lowering 20mm. The change to 20” wheels and slightly lower profile tires was a bit noticeable in that every man hole cover and bump can be felt a bit more clearly although even that was a subtle change. I actually use comfort mode now more since the fender gaps no longer look hideous at the slightly higher ride height. I’m sure it will depend on how much you lower it. The great thing about this module is that it’s easily adjustable.
Exup99 (04-11-2018)
Old 04-11-2018, 05:18 PM
  #59
Exup99's Avatar
E350T Bluetec
Thanks a lot for the inputs.
The idea is really just to decrease the fender gaps (probably further 10mm from the sport mode). Where I live (Germany ) I'm lucky to have very good roads...but I wouldn't like to loose all of the comfort of the airmatic :-)
Old 04-14-2018, 07:46 PM
  #60
Clkboi's Avatar
CLS550 4Matic
Finally got around to trying it out today!
It works exactly as advertised.
First I had the car in position 1 and got this weird message. Make sure your ignition is on for itAnyone tried this OBD2 Lowering Module?-photo294.jpg
I didn't play with the manual mode I only put it on the "Low" setting and it's low enough for me honestly
Front lowered
Rear lowered
As soon as I changed the settings and started the engine I put my hand on the tire and could feel it lowering and it's pretty fast.
Very satisfied with this device! To anyone thinking twice about it; Don't!
Old 04-14-2018, 07:49 PM
  #61
2015 cls550
First I had the car in position 1 and got this weird message. Make sure your ignition is on for itAttachment 416255
Front lowered
Attachment 416257
Rear lowered
Attachment 416256
Sweet. I got my module in the mail a couple days ago . Still waiting on the car to be delivered lol. Can't wait
Old 04-14-2018, 07:51 PM
  #62
Clkboi's Avatar
CLS550 4Matic
Lol you did the same thing as me. I didn't have the car and bought a bunch of parts for it before even making a purchase. I knew I was going to get a CLS and didn't care
Old 04-14-2018, 07:53 PM
  #63
2015 cls550
Ya. I bought the car a couple weeks ago but waiting for it to be shipped here ... Meanwhile parts are arriving... Lol
Old 04-14-2018, 07:54 PM
  #64
Clkboi's Avatar
CLS550 4Matic
Nothing wrong with that. The sooner the better.
What year and color combo did you get?
Old 04-14-2018, 07:56 PM
  #65
2016 CLS550 4Matic
If anyone is getting their alignment done after lowering, can you please checkin on this thread... https://mbworld.org/forums/cls-coupe...ent-specs.html
Old 04-14-2018, 08:05 PM
  #66
2015 cls550
2015 Obsidian Black
​​​​​​Fairly loaded.
Check my posts for pics
Old 04-14-2018, 08:07 PM
  #67
Clkboi's Avatar
CLS550 4Matic
2015 Obsidian Black
gorgeous
Old 04-14-2018, 08:08 PM
  #68
Clkboi's Avatar
CLS550 4Matic
i saw that thread. I will be getting an aligment probably in a week or so. ill post the print outs after. Hopefully someone replies to you sooner though
Old 04-14-2018, 08:10 PM
  #69
2015 cls550
This will help me immensely too.
Old 04-14-2018, 09:41 PM
  #70
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Would this work with 2012-2013 models? OP I assume has newer comand..
Old 04-14-2018, 09:45 PM
  #71
2015 cls550
You can message the guy on eBay.. don't hold me to it but I think it works on yours as well.
Old 04-14-2018, 09:49 PM
  #72
djrabbi's Avatar
I haven't bought my next CLS yet but beats buying an $800 module plus install! I will message him though
Old 04-14-2018, 10:51 PM
  #73
Clkboi's Avatar
CLS550 4Matic
Yes! Mine is a 12. After you buy he will ask you for a vin to confirm and then you go ahead and actually purchase (2 steps on eBay)
Good luck
Old 04-17-2018, 08:51 AM
  #74
vladimir.cdi's Avatar
E43AMG
both audio head units supported NTG4.5 and NTG 5s1 (both COMAND and Audio20) so any CLS C218 with airmatic suspension (SA489) supported no problem
Old 04-19-2018, 08:21 PM
  #75
bob2011's Avatar
2011 E550
Would this void the airmatic suspension warranty? Got another 4 years on my coverage, wouldn't want to jeopardize that lol.
Quick Reply: Anyone tried this OBD2 Lowering Module?
