Parktronic - 2 Red lights and a beep
Old Jan 19, 2020 | 06:35 PM
therocket's Avatar
2013 CLS550
This intermittent problem started a couple of weeks ago. After the beep, the sensors turn off. I cleaned all the sensors but it still happens here and there. I am thinking if the sensors were bad, it would beep every time and not on every 2-3 starts.
Any suggestions as to what could be the cause of this?
Old Jan 19, 2020 | 09:04 PM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
I can't tell you what it is, but you need to get it read with a MB Star Diagnostics system to get you on the right track. Marv
Old Jan 19, 2020 | 09:51 PM
bob2011's Avatar
2011 E550
Does it happen every time you start the car? Or is it kind of random?
Old Jan 20, 2020 | 12:21 AM
Dblok1113's Avatar
2014 CLS 550
Mine does the same thing, I turn the car off and on and it ends up working fine. So weird and random.
Old Jan 20, 2020 | 08:29 AM
konigstiger's Avatar
'71 Pinto
Given circumstances, check battery (engine compartment).
Old Jan 20, 2020 | 04:07 PM
therocket's Avatar
2013 CLS550
Yeah, this happens randomly. @konigstiger What specifically about the battery should I check?
Old Jan 20, 2020 | 04:32 PM
'71 Pinto
Fully charged, given intermittent problem occasionally this is the cause.
Old Jan 20, 2020 | 04:47 PM
Tbbt CLS's Avatar
therocket,
Do you know if this the original battery in your car? If so, you're working on borrowed time. Especially in a car that is so electronically controlled. You should also check the auxiliary battery too. Marv
Old Jan 20, 2020 | 06:34 PM
therocket's Avatar
2013 CLS550
Not sure since I recently purchased the car but will check to see if it is the original battery.
Old Jan 20, 2020 | 08:46 PM
Tbbt CLS's Avatar
I'd have the battery load tested for service life!
Old Jan 22, 2020 | 07:11 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
As previously stated. My battery ended up fixing mine. I had a similar issue.
John
Old Jan 22, 2020 | 08:08 PM
TheFranchizeSLB's Avatar
2014 Mercedes Benz CLS 550
i dont think its auxiliary battery issue.. i brought mine in for speed sensor service/fix and mentioned it happening to mine and was told the car needed a software update as my eco mode stopped working, as well... i am tuned so i declined said update and since im good with my SA he told me prior to just doing it... see if that is the issue.. i had my aux battery changed and it fixed nothing...
Old Jan 22, 2020 | 08:49 PM
therocket's Avatar
2013 CLS550
Yeah, I have the OE tune as well so I would prefer not to do a software update. I will start by testing the battery and then go from there.
Old Jan 25, 2020 | 03:48 PM
therocket's Avatar
2013 CLS550
Battery photo
I assume this is the original battery and the cause of the issue based on the date?
Old Jan 25, 2020 | 04:22 PM
Tbbt CLS's Avatar
The date code reads 23rd week of 2012. What is your build date (on the drivers' door post)? I'm betting it's the original battery. Have you had it load tested yet?
Marv
Old Jan 25, 2020 | 04:27 PM
therocket's Avatar
2013 CLS550
06/12 so it must be the original one. Have not had it tested yet but doing that next. Appreciate your help
Old Jan 25, 2020 | 09:59 PM
therocket's Avatar
2013 CLS550
I found a replacement battery at Costco in case the load test fails. Does the new battery need to be programmed? I remember it had to for my BMW but not sure about the Benz.
Old Jan 25, 2020 | 10:51 PM
Tbbt CLS's Avatar
I haven't found any posts on it yet. There are 9V adapters that you plug into your cigarette lighter and it should save your presets (I think). Marv
Old Jan 26, 2020 | 09:57 AM
'71 Pinto
No, see attachment.
File Type: pdf
