P254000 Fault Code Help
Old Jan 24, 2021 | 08:27 AM
simonyet's Avatar
CLS400 (218.365)
Hi guys, my car was diagnosed with Xentry and there was a F code with current and stored marked.
The problem was in FSCU07 control unit 'Fuel Pump' dignosis identifier P254000 "the signal for the pressure sensor of the low pressure fuel circuit is implaussible"
I have sent it to MB authorized service center, they found a small leak at the top of the fuel tank because my O ring seal not elastic anymore then they change it to the new one and clean the pressure sensor with contact cleaner.
They have tried to change the fuel pump pressure sensor and the F code gone then they tried to change it back with my old fuel pump pressure sensor which has already cleaned and there is no issue too.
I got back my car from workshop, use it for 1 day then i check again with xentry the F code return.
Anyone has this experience before?
How to solve it? do i have to change the fuel pump pressure sensor or the fuel pump itself?
Old Jan 24, 2021 | 09:33 AM
konigstiger's Avatar
'71 Pinto
Request they revisit connections assuring all are properly secured and if so, replace fuel pump.
Old Jan 25, 2021 | 07:30 AM
simonyet's Avatar
CLS400 (218.365)
do i really need change the fuel pump? because the pressure bar and voltage were good. pressure bar about 5.8 at idle and 6.0-6.1 when rev the accelerator. The voltage about 5.0V which the recommendation numbers are 1.6-16.0V
or maybe should i change the new fuel pressure sensor because they just clean the sensor with cleaner.
Old Feb 4, 2021 | 12:40 AM
simonyet's Avatar
CLS400 (218.365)
update here.
i have change the fuel pressure sensor but the Fault code back again.
actually no real problem happen regarding this Fault, it only can be detected when we scan the car with xentry.
i still figure out what hardware i should change, some told me its a control unit fuel pump and others told me its a fuel pump.
or maybe better i wait until something real affect my car performance?
Old Feb 4, 2021 | 10:35 AM
cls5504matic's Avatar
C63 Vert
Originally Posted by simonyet
update here.
i would follow konig’s advice.
