CLS 550 2012 vibration on steering and sometime pedals
Old Oct 2, 2024 | 09:53 AM
mohamed25xx's Avatar
Mercedes cls
Hi ,
i have a cls 550 2012 model
i have vibration on steering wheel while idle and also while driving but it increase while driving the car it most at speed of 110km and above sometimes it also vibrate on the pedals down but keep coming and going
i have change the engine and transmission mount
change the tires to brand new and also had a doubt on the rims and have change the rims to original 19 inch AMG rims
change the low arms from both sides
changed the inner and outer road tie from both sides
changed the road link in both sides
changed the stabilizer sway bar
changed the hydraulic suspension both sides
made balancing 4 times
i have a spacers in both front side 15mm also and has been changed thought maybe its the problem
still problem occurs , yes its reduced but its still there ..
Please any one can help what else i should check
Old Oct 2, 2024 | 02:30 PM
PekkaH's Avatar
2015 CLS550 Shooting brake 4-matic
Originally Posted by mohamed25xx
Hi ,
Hi
You have swap a lot there to fix that problem! You did mention it vibrate on idle also. How much is your car driven? Have you change lambdas? My car did vibrate on idle but not just the steering wheel and it stopped when all lambdas were swap to new ones. Also many more things get better, like throttle response etc.
Old Oct 3, 2024 | 12:38 PM
Mercedes cls
I didn't change that as it didn't come to my mind that the problem vibration in steering wheel would come from it ..
forget to mention also that the wheel bearing has been checked but its all good
do you think it may be the steering box have any screw lose or something which make it vibrate ?
what makes me crazy that it keep going and coming
today i drive the car and get know its fully no vibration when i was idle and rpm was at 500
Old Oct 5, 2024 | 01:46 PM
Mercedes cls
Any one can help ?
Old Oct 8, 2024 | 09:09 PM
Beer_Bandit's Avatar
CLS500
STOP guessing, and take it to either the dealership or an independent for a proper diagnosis.
Old Oct 11, 2024 | 02:42 PM
Mercedes cls
I went for 4 shops they mentioned there is no issue can be seen as all parts are new now and nothing can be found as defective..
