P1CE7 and misfire codes - fixes
Old Nov 17, 2024 | 09:03 PM
J_Sellers's Avatar
My car had thrown a code for P1CE7 PCV valve not operating correctly under WOT and a misfire code. I assume these are related, and my research has led me to believe that the problems lies in my aftermarket Blackboost intake.
I apologize if this particular follow up question is already answered, I couldn’t find anything and am curious on possible solutions and clarification from those with experience.
Am I likely correct in thinking that the PCV issue was caused by the intake, and that the misfire was in turn a result of this PCV issue? I know a tune can remove the code for the PCV, but if this issue causes a misfire this route won’t accomplish anything but ensuring that I don’t get the P1CE7 code. Unless somehow it could adjust the A/F or PCV valve operation electronically, which I doubt or else it would be too easy to fix.
I am trying to determine how I should handle this moving forward, so the big question is how exactly people who have faced this problem resolved it. Should resolving the PCV issue clear up the reason for the miss? I’m assuming so, unless I do legitimately have a Vac leak in a line and the logic that it is my intake based on other’s experiences is invalid.
Old Nov 17, 2024 | 10:02 PM
J_Sellers's Avatar
I was going to message @Cifdig or @HDTuning but I don’t think it will let me due to fresh account.
Old Nov 19, 2024 | 09:11 AM
95viper's Avatar
2007 cls550
I am fixing a similar problem now although on an oem intake on a cls400. I replaced the high flow check valve assembly and now am doing the assembly to the air/oil separator under the intake as this routes to the check valve next to intake.
