CLS Coupe (C219) Discuss the CLS Coupe.
Where to install Amp BAss Remote Gain
Old Sep 2, 2012 | 06:01 PM
freemanjc's Avatar
CLS 550
I have look from the rear of the trunk and can't seem to find a good route to run an amplifier bass remote to the front of the car. However, I came across this gadget and wonder if anyonehas used this item or has any experience with it. This is thr only viable solution I see.
http://www.sonicelectronix.com/item_...BL-MS-WBC.html
Old Sep 3, 2012 | 02:52 AM
ydlee's Avatar
06 CLS500, 07 GL450
I have the Rockford fosgate 360 and my knob is under center of steering wheel bottom panel. Ran from the door sills.
Old Sep 3, 2012 | 05:07 PM
freemanjc's Avatar
CLS 550
YDlee,
How did you get it from the trunk into the cabin? I see no possible way to do so, can you elaborate further indetail.
Old Sep 3, 2012 | 11:11 PM
ydlee's Avatar
06 CLS500, 07 GL450
Originally Posted by freemanjc
YDlee,
You have take the panels off in trunk and run the cable through to backseat might have to remove bottom seat and then remove door plastic bottom trim by carpet footwell and run wires.
