CLS Coupe (C219) Discuss the CLS Coupe.
2014 CLS550 4Matic with Beltronics STi-R and Blinder HP-905 Quad, Midcity Engineering
Old Nov 4, 2013 | 08:34 PM
TagsVC's Avatar
2014 CLS550 4Matic Steel Grey Metallic Black Ash Trim
Just had the Beltronics STi-R Plus (clone of the Escort Passport 9500ci), Blinder HP-905 Quad and MidCity Engineering interface installed.
I was doing triple digits when I got hit with a laser. Was able to slow down then I turned off the system.
Works flawlessly.
Here is a picture of the control integration.
2014 CLS550 4Matic with Beltronics STi-R and Blinder HP-905 Quad, Midcity Engineering-image-1553036466.jpg
Old Nov 4, 2013 | 09:33 PM
Newzchspy's Avatar
PLAID
Originally Posted by TagsVC
Just had the Beltronics STi-R (clone of the Escort Passport 9500ci), Blinder HP-905 Quad and MidCity Engineering interface installed.
Works flawlessly.
Attachment 270780
All that picture shows is the control for the Stir. Note that Stir is not a clone of the 9500ci as the Ci has GPS and the Stir does not. You may be referring to the stir +, which does indeed have GPS.
Blinder HP 905s are not easily updateable and are old technology when it comes to jammers. The gold standard of jammers is the LI.
Old Nov 4, 2013 | 09:42 PM
TagsVC's Avatar
It is indeed the STi-R +
I personally have had similar results with the Blinder system and the Laser Interceptor.
There was no real delta for me to go either way.
Old Nov 5, 2013 | 09:14 PM
KeepRtPassLeft's Avatar
1970 220D
Both the Blinder and the LI will serve most users well when installed correctly The performance of the two systems are similar with a slight edge to the Laser Interceptor.
The technology in both the Laser Interceptor and Blinder HP905 are very similar. The Blinder is actually easier to update, but doesn't have updates often. The LI needs a USB to Serial cable, that you have to purchase separately. Some of these cables aren't compatible with the LI, and some aren't compatible with some versions of Windows, and some have many firmware versions that may or may not work with the LI or your version of Windows. The LI must be powered by a separate 12V power source when updating. The Blinder only needs a USB connection to your computer.
The best performing laser jammer based on testing is the AntiLaser Priority.
