2006 219 Cls front window movement.
2006 219 CLS
I have a 2006 cls and I have found the front window has moved forward away from the door seal, I was able to push window back into correct position again but it is starting to move forward again. How can I fix this problem? Hope someone can help. Thanks Alistair.
2007 Mercedes E550
Did you recently disconnect the battery? If so, the windows may not go up all the way and you need to resync, instructions are in the owners manual. Hop this helps!! Feel free to PM if you have questions!
