Exhaust heat shield and reduced transmission temperature!
1 Attachment(s)
Just FYI-I installed two Thermotec clamp on exhaust heat shields along the sections that run alongside the transmission and to my surprise the transmission fluid temperature has reduced by an average of 50-70 degrees F!
For those that plan to track your GT, I think this is an extremely cheap and effective upgrade to reduce transmission temperature! |
Thanks for the info and tip.
Just came back from Road Atlanta ADA Pro and the cars were able to handle 15 min sessions with one cool down lap one after the other for a few hours with no issues at all. What kind of temperatures were you seeing on your end and how long of a session are you running? |
Originally Posted by emericr
(Post 7168847)
Just came back from Road Atlanta ADA Pro and the cars were able to handle 15 min sessions with one cool down lap one after the other for a few hours with no issues at all. What kind of temperatures were you seeing on your end and how long of a session are you running? I haven't hit the track yet. My trans temp usually register about 180-195 in city/freeway driving when ambient temperature is around 75-85 degrees. Since the heat shield installation it has been hovering around 130-140 in the same conditions. My transmission is also taking about 10 minutes longer to get up to temperature. The exhaust pipes come very close to the transmission at certain areas (0.5" -1"). These heat shields create air gaps between the exhaust and shield shields and transmission. |
I like simple solutions like this do you have a link?
Originally Posted by AMG 17GT
(Post 7168863)
Summit Racing or Jegs carried them. Here's the link to Summit: https://www.summitracing.com/parts/THE-11675 Jegs: http://www.jegs.com/i/Thermo-Tec/893/11675/10002/-1 |
Now that I think about it taking those two hot 2nd catalysts off has definitely changed the time it takes for car to warm up. Boiler did you cut out ?
Thank you!
was it an easy install? I have a couple of track days coming up and this is of great interest to me. Could you maybe post some pics of the locations you've installed these? The engine bays are pretty crowded and the more info I have the better I feel. Thanks in advance.
Oren |
Originally Posted by orenlasko
(Post 7169472)
Oren As for the temperature of the trans fluid, it'll eventually stabalize at about 180 degrees, but it'll take a long time to get there because the heat is generated by transmission and not being heated by the exhaust pipes. But on mine it doesn't get any hotter than 185 or so whereas before it exceeded well over 220 at times. |
Wow I fee like an idiot.
I keep forgetting the transmission is in the rear. I just automatically keep thinking of cooler lines and such. Thanks for the clarification. Cheers!
Originally Posted by 300blackout
(Post 7169540)
yeah it's really easy. The transmission is in the rear of the car. Just remove the under panel and it'll be obvious to you where to put it.
As for the temperature of the trans fluid, it'll eventually stabalize at about 180 degrees, but it'll take a long time to get there because the heat is generated by transmission and not being heated by the exhaust pipes. But on mine it doesn't get any hotter than 185 or so whereas before it exceeded well over 220 at times. Also are the fasteners that come with shield sufficient? |
(Post 7169557)
I'm assuming you got the 12" lengths X 2?
Looking to do this mod - would the best time to have this be done when I'm having the secondary cats removed? Is this located in the same general location?
Originally Posted by larrymz3
(Post 7172863)
Any pics?
(Post 7173149)
Any pics?
https://mbworld.org/forums/amg-gt-gt...downpipes.html |
(Post 7173149)
Any pics?
(Post 7168863)
I know the M3/4 F80/82 suffers on track a little. |
can you take pics of your install
can you take a few [ics of the install?
(Post 7168809)
(Post 7168847)
