Brake job cost?
Brake job cost?
Been looking into picking up a gts and was surprised at the cost for front and rear rotor and pad replacement with steel brakes. Over 7k?!? Are you guys going aftermarket when needing to replace the rotors and pads?
‘24 BMW iX M60
Why is the car needing the brakes replaced? Mileage on the car?
I would get the brakes replaced at an independent shop versus the dealership using OEM parts that I’d purchased on-line from a cheaper source, or look to companies like AP Racing; Girodisc, etc. for replacement rotors, pads.
The front rotor part number is: MERCEDES-BENZ 2304211212 which is a Brembo 09.9313.33 and the exact same part and can be had for $367 on eBay today and also sold on AMZN or $732 for a set of 2 also on eBay.
See the data sheet linked here https://www.bremboparts.com/europe/e...isc/09-9313-33
The rear rotor part number is: MERCEDES BENZ 2224232012 which is a Brembo 09.B879.11 and you can find those for about $85 each or here https://www.brembostoreusa.com/produ...c190-r231-w205
See the data sheet linked here https://www.bremboparts.com/europe/e...isc/09-B879-11
As I track my AMG GT-S I have replaced the front rotors 3 times and I am about to replace the rear rotors.
Front pads are MERCEDES BENZ 0074206520
Rear pads are MERCEDES BENZ 0084201120
and you can get a set of front and rear OEM pads for $369 on eBay. There a several equivalents and you can get some from Pelican parts for example.
You can always get the girodics replacement disc kit which are 1300 for fronts and also 1300 for rears then then 700 for rotor alone.
Just as a side note the rear brake calipers, at least on my GTR, are not brembo they are TRW and the replacement caliper kit cost $500.
Wow great info here on the brembo rotors at almost 1/3 the cost of buying through Mercedes. Are these brembo rotors exactly the same or just the same dimensions but different vaning, drill pattern, etc. Interesting that no one seems to sell the disc ring separate from the hat. Isn't that supposed to be one of the benefits of these two piece rotors?
Pete De La Mare (08-13-2019)
2021 Porsche TTS
Much appreciated. Gotta love this forum.
This will save us quite a bit. Drinks are on me if you are ever in my neck of the woods
Just an update here on the Porterfield pads and endless fluid. The shop got them directly from Porterfield in California.
Brakes grab much better and are more linear than the stock pads. Brake dust is greatly reduced and the car just feels great stopping no more mush feel in pedal. Highly recommended.
EDIT
forgot to mention that he blew out the intercoolers and there was one inch of sand/pebbles on each side. You should have this done with each oil change. He really couldn’t believe how much debris was in there, as a plume of dust. shot out.
Also, blue ridge Mercedes in Lilburn is a fantastic shop that specializes in a lot of older AMG’s. They have six hammers there which is incredible and a couple of widebodies which are so rare. They were doing some incredible rebuilds which make it a lot of fun just to walk around and see the projects that he’s getting from all over the US.
If there is one Achilles’ heel on my GT is that the rear rolls too much in hard corners and sweepers. Jonathan the owner, is reaching out to a race team on the GT for some part numbers on the rear sway bar’s and rear links. The rear sway bar is way up in there, but he thinks that there’s a simple solution with the Links.
EDIT
emericr (08-17-2019)
