Drivetrain failure
Old Feb 22, 2020 | 11:08 AM
wawrecker's Avatar
CAV GT40, 2018 GT R, 2019 GLC 63, 13' Ford Raptor,
Drivetrain failure
Took the car out for a cruise after work last night. About 10 minutes into the drive I noticed when the car shifted it was chattering and progressively getting worse. I exited the highway as the car came to a stop the noise got louder. A combination of thumping and grinding. Car barely moved off the road to the shoulder. I suspect the drive shaft came apart. It’s at the dealer now I’ll update when I hear what happened. Car had 7000 miles when I got it.
Old Feb 22, 2020 | 12:09 PM
AMG 17GT's Avatar
R Nine T
Recall hopefully
Old Feb 22, 2020 | 09:02 PM
UCIMBZ's Avatar
E55, 380SL, GLA 250 Sport, AMG GTS
Originally Posted by AMG 17GT
Recall hopefully
It's a 2018 GTR. No recall campaign on those. But warranty for sure.
Old Feb 23, 2020 | 08:07 AM
ChargedMB's Avatar
2018? gosh damn, hopefully not a continuation of the issue in the earlier GTs
Old Feb 23, 2020 | 04:22 PM
thebishman's Avatar
‘24 BMW iX M60
First major drivetrain failure on a GTR that has been reported here iirc.
keep us in the loop as to cause.
Bish
Old Feb 24, 2020 | 01:27 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Question: did you buy it "new" from a dealership with 7,000 miles on it? Or, was it titled to another owner before you?
Old Feb 24, 2020 | 01:29 PM
wawrecker's Avatar
It was titled new to a previous owner. Why do you ask? Thanks
Old Feb 24, 2020 | 07:00 PM
///Bruce's Avatar
If it was first titled with a few thousand miles, it was first “used” by the agency. One owner7k miles. Sounds good.
Old Feb 25, 2020 | 09:09 PM
wawrecker's Avatar
Dealer called with first update. They are unable to find any trouble codes and the car drove fine, no indication of mechanical issues. They will take it out for a longer test drive and report back. This is hard to believe, nothing about it was subtle when it happened while I was driving it. I'll report more when I hear anything.
Old Feb 26, 2020 | 08:08 AM
realien's Avatar
2016 AMG GTS
I have had the same error on my GTS, no codes, usually after the rain. Research seems to affect other cars with the similar diff and motor and appears to be either a software update, a plug in the diff, the speed gear and in one case a new diff was needed.
Old Feb 27, 2020 | 02:07 PM
wawrecker's Avatar
Dealer was able to get the car to malfunction or act up today. They have no idea what is going on and are at a loss to explain and said they are getting MB in Germany involved. Will post again when I know more. They did say prior test drives were done in comfort and today it was in sport plus when the failure occurred.
Old Feb 27, 2020 | 10:02 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
I would go to a new dealer - it doesn’t sound like they know what they are doing. They’ve made no progress since you left it there.
Old Feb 28, 2020 | 06:00 AM
rt7085's Avatar
Solarbeam Yellow 2016 AMG GTS
Subscribed. Curious what the root cause is.
Old Feb 28, 2020 | 06:22 AM
JSwan724's Avatar
2024 AMG G63 2025 Ferrari SF90 AF Spider
So they are making some progress.
It’s important for you to know that the dealer hooks your car up to their diagnostic database in Germany. All known issues for your car model worldwide are documented there using a protocol the local AMG tech specialist has to follow. If the issue isn’t known and shortly after working with the Germany tech specialist, they will send a regional tech to work with the local one and the factory to attempt to further identify the root cause and solution. YOU DON’T NEED TO DO ANYTHING but be patient. As the country boys say, you are plowing fresh snow here. But it will be easier for the next occurrence since everything is documented thanks to you.
Best regards
Jerry
Old Feb 28, 2020 | 01:06 PM
dlefty's Avatar
/////PRO
Actually to me, sounds like they know EXACTLY what they are doing following procedures set forth by MB.
Old Feb 28, 2020 | 01:16 PM
Surge's Avatar
Not at all. They’ve done nothing but wonder what the issue is. My AMG tech would be a lot more proactive and knowledgeable- this is not acceptable- but anyway, let’s see what the issue is.
Old Mar 1, 2020 | 11:55 PM
MercAMGgts2016's Avatar
AMG GT S
They managed to recreate the problem
That literally is the definition of progress ROFLOL
Old Mar 4, 2020 | 12:04 PM
realien's Avatar
2016 AMG GTS
any updates ? Mine popups that error randomly, only code we have found is a voltage issue and MB has a bolt on piggy back voltage regulator I may be trying out (out of wrarranty), the the service team has put on about 6 GT's with this issue
Old Mar 4, 2020 | 01:21 PM
wawrecker's Avatar
Talked to the dealer today. They have updated software and have not had another incident since. They are keeping the car for a few days to road test to ensure the problem has cleared. The tech that’s working on it was not in so I was unable to get more specific information. I will find out what the update was when it’s done. I’m concerned with accelerated wear as the event was extremely harsh given the noise and vibration.
Old Mar 4, 2020 | 02:16 PM
realien's Avatar
2016 AMG GTS
hmm checking other issues since it also seems to occur in the E class E63s... it was , software, or speed gear, or diff...
Old Mar 4, 2020 | 02:18 PM
Pete400's Avatar
C400
This happens in my Vantage also usually during starting or stopping the engine
Old Mar 5, 2020 | 04:24 PM
wawrecker's Avatar
Picked up the car today. Per the dealer: Installed a newer version of ECM and TCM software, that is it. If I didn't have a couple years of warranty left I would be highly concerned about longevity. I expect to be tracking the car in April so any issues I expect will be revealed then.
Old Mar 5, 2020 | 05:03 PM
realien's Avatar
2016 AMG GTS
Glad they got it figured out, I'll probably be doing the same soon.
Old Mar 5, 2020 | 06:39 PM
JSwan724's Avatar
Glad your issue is resolved.
BTW:Your copy of the service ticket will have detailed information on what was done, parts replaced, diagnostic codes detected and hours spent.
Now its time to enjoy your car.
Best regards
Jerry
Old Apr 8, 2020 | 08:23 PM
wawrecker's Avatar
Appears the software update did not do the trick. I've put about 1500 miles on the car since the incident. Today when I came to a stop after about 30 minutes of driving the shudder returned. Its almost like the clutch is engaging and disengaging, the car noticeably rocks back and forth but not in reverse. Give it some gas and go and it seems ok although the shifting seems a little off and firmer. I decided to drive it back to the barn and I heard a metallic bang or ping from the rear and at the next stop light the problem was gone. I'm going to send it to the dealer as soon as I hear back from them as they are on COVID hours. Once again, I will update as I hear whats going on. Everything I've read about these transmissions is pretty solid of late.
