AMG gt-s oil leak
Old Aug 4, 2021 | 01:35 AM
Hongzhang's Avatar
amg gt-s
AMG gt-s oil leak
I have a AMG GT-S oil leaking from engine rear main oil seal.
After replace the oil seal it still leaking,If it has other possibilities caused leaking.
Hope it can give us some ideas,Thanks
Old Aug 4, 2021 | 04:07 PM
4wheelz's Avatar
None yet
How often do you drive the car? There was a thread a while back about the seals drying out if the car sits for long periods of time without being run, then once run for a bit, the seals are back in working order.
Old Aug 4, 2021 | 04:46 PM
AMG 17GT's Avatar
R Nine T
If the leak is not the rear main seal, it is probably the DCT, as that is exactly what is described as a symptom of the problem.
Old May 11, 2022 | 03:34 AM
ks4life's Avatar
w204
I have same symptoms. Did you get it fixed? if so, please share your experiences.
