GT R Pro vs BS performance
But the difference is going to be significant in favor of the BS. Even if your assumptions are correct about the time improvement at the ring because of different tires, 10 seconds at that range, where each second is exponentially more difficult to gain, is massive. I also think you're crediting the tires with too much time gain.
It would be interesting to actually see them side by side but the power and downforce advantages of the BS are considerable ... let's put it this way, the improvement of the BS over the Pro is going to be greater than the Pro over the R.
Difficult to dispute the performance of this car compared to past performance. Make tires match....or not. In the right hands, this car is a killer.
The BS is a level above in terms of aero dynamic design which matters a lot for the high HP GT cars, I think the gap will probably be very significant on high speed tracks or high downforce track, slightly smaller in technical tracks but nothing trivial.
I might be able to keep a really bad BS driver in my sights. lol.
I am not inclined to add more power to the PRO at this time. Car can be a handful on corner exits with the power on hand.
The stock configuration did very well within reasonable expectation.
Once tuned or tuned + downpipes, the car got to be a lot more of a handful, not so much because of the extra power, but where the extra power and increased torque was.
Many of the tunes and tuning companies out there are working within the “limitations” of the stock turbos, having a bunch of torque down low, and adding all the power low to mid range, as the factory turbo is a dog after 5k RPM, it simply cannot flow enough air. So after a tune the car gets even more wild out of corners when coming back on power or those types low to mid range throttle application situations.
One thing i saw and experienced personally was going to a big turbo that moves the torque and power band “to the right” some, is more linearity, predictability, at those lower RPM or initial throttle application situations. As well as a super amount of power and pull all the way to redline, never running out of breath. If anything. It oddly almost made it easier to drive in those situations. Go figure, an extra 150-200hp easier to drive, mostly due to lacking that instant punch from a factory sized turbo…also an interesting side effect of the larger housing turbos, they run cooler as they are not as maxed out under increased boost levels from a tune.
