Gear ratios for MY 2018 GT R (North America)
Old Oct 18, 2022 | 06:45 AM
sevenhead's Avatar
2018 Mercedes-AMG GT R Evo
Can't seem to find these. The only thing I found was the final drive of 3.88:1.
I'm interested in seeing the maximum speed permissible in each gear. Back in the day this was included in any road test.
Thanks for any help. My calculator awaits.
Old Oct 18, 2022 | 08:25 AM
G. P's Avatar
2020 AMG GTC
Gear ratios (overall):
I 3.08 (11.95)
II 2.19 (8.5)
III 1.63 (6.32)
IV 1.29 (5.01)
V 1.03 (4)
VI 0.84 (3.26)
VII 0.7 (2.72)
Final drive ratio std: 3.88
Just keep in mind that permissible is very theoretical at speeds over about 120MPH. Drag will slow you down considerably as your speed goes up.
The GTR theoretical speed can be at 215MPH at 7th gear, but drag will limit it to about 200. To overcome some of the drag limits and gain more speed over the 200, you will need more HP = Tune.
Old Oct 18, 2022 | 12:53 PM
sevenhead's Avatar
Many thanks for that G.P. I am well aware of the role that aerodynamics play. My Lotus Seven is a brick after 100 mph so I just played with gearbox ratios and to a lesser extent final drive ratios.
Old Oct 18, 2022 | 01:54 PM
G. P's Avatar
2020 AMG GTC
Wow, that is amazing. What Year and version of the Lotus Seven do you have? any Pics?
Old Oct 18, 2022 | 02:08 PM
user33's Avatar
This site often has fairly complete and accurate data:
https://www.automobile-catalog.com/
... including the theoretical max speed by gear:
https://www.automobile-catalog.com/auta_details1.php
Old Oct 19, 2022 | 03:16 PM
AndrewFerg's Avatar
AMG GT C Edition 50
I was curious about this as well, so I went out to a mostly vacant road and floored it and noted the results. Much easier than using a calculator. Oh, and a lot more fun too.
Old Oct 19, 2022 | 05:38 PM
sevenhead's Avatar
Imported in 1961 as a Lotus Seven America.
My dad acquired it in the '70s.
He promptly dismantled it.
When he died in 1992 I had to sort through his 50 year accumulation of British and VW stuff.
I had a new and improved chassis built for it so it looks like this now.
First iteration
Second iteration
Old Oct 19, 2022 | 05:49 PM
sevenhead's Avatar
Shifting at 7000 calculator says:
1st - 48 MPH
2nd - 68
3rd - 91
4th - 115
5th - 144
6th - 177
7th - 212
All speeds theoretical
Old Oct 19, 2022 | 09:00 PM
G. P's Avatar
2020 AMG GTC
Very impressive. Great reconstruction and similarity to the Seven line
Old Oct 20, 2022 | 03:59 AM
sevenhead's Avatar
Thank you.
I would hope so since I had the chassis and factory drawing at the disposal of the fabricator. Series 2 cars are notably weak so we made a number of improvements. I wasn't interested in going back to Sprite power and I had several English Ford engines available so I built up a 1500cc pre-crossflow. Makes perhaps 85 BHP and the car weighs 1100 lbs.
