Another newbie question
E55
I have an E55. The manual says do not use leather cleaner on hte seats -- since it has a protecitve coating.
But there are leather-like material on hte dash and the inside of hte doors. What should I use on them? Leather cleaners or osmething else -- like interior cleaners?
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations ~
Coated Leather: leather made from natural hides, but uniquely treated with a light pigmented urethane resin coating to make it more suitable for automotive seating. It retains the softness of natural top-grain leather but resists fading in direct sunlight. Spills wipe off with a moist cloth, retains the aura of natural leather without its sensitivity to light and abuse. The urethane resin coating requires oils to stop it from drying out (just like a paint system’s clear coat) coated leather and its vinyl can be cleaned with a leather cleaner, but do not clean leather with a cleaner formulated for vinyl. Clean / condition / UV protect as in 1, 2, 3 page 1.
http://www.autoskin.com.
Leather cleaning / conditioning is a three step process, comprising; Cleaning, Conditioning and UV radiation protection
1. Cleaning- use a soft horse hair brush (Groit’s Leather & Interior Brush) and/or a vacuum to remove any dust, apply a cleaning solution (Water /Woolite or Dreft 6:1 ratio or stronger) on to an applicator pad and apply to one area at a time (i.e. a seat back). To remove stubborn dirt or grime gently agitate the surface with a boar’s hair cleaning brush (this will not harm the leather) then use a clean, damp Microfiber towel to rinse.
Stubborn stains- dependent upon the leathers condition or how dirty it is consider using a leather-cleaning product. (Leatherique’s Prestine Clean, Groit’s Leather Cleaner or Autoglym Leather Cleaner)
With all cleaning products, always test a small, indiscrete area first to ensure it won’t discolour or stain the surface, and ensure that the pH of the product is suitable for the material.
2. Maintenance- recommend a preventative maintenance routine three to four times a year, once prior to the winter season to prevent cold temperatures cracking the leather, and once before the heat of the summer to prevent deterioration and shrinkage by heat, which result in continued cracking of leather. In addition to regular cleaning, leather requires replacement of natural oils; Collagen-based products restore the lost moisture and maintain it’s natural flexibility. The smell of leather comes from oils evaporating out of the hide. Once every 30-60 days, Arizona, Florida and Texas, especially in summer, for northern climates between 90-120 days, use a leather conditioner to restore these natural oils and keep the leather soft and supple. (Criot’s Leather Care, Autoglym Leather Care Cream or Zymol Treat leather cleaners are all good maintenance products)
3. UVR Protection- you should consider additional sunscreen protection (especially if you own a convertible) Leather conditioners typically do not offer any UV screening. The best solution is to alternate between a leather conditioner and a UVR Protectant. One month use a conditioner to keep the leather healthy and supple. On alternate months mist and wipe the leather with a UV protectant. After application allow 60 minutes for product to cure, then using a 100% cotton cloth lightly buff surface.
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect * so I question everything *
~Hope this helps~
