Solution for extremely scratched HID lenses?
Just got a pair of HID headlights for my W208, the headlights were shipped really crappy. The lense of one of them was really scratched to a dull finish. Any solution? Send them back? (Dunno if the seller will take them back...you know, ebay )
Thanks for your help.
KEv
KEv
I would contact the seller and explain that when you bid on them you expected to receive useable lights which these are NOT. and before you give him a very negative feedback review, you wanted to give him the chance to make it right.
Also if you payed by paypal you can complain to them.
Good Luck.
Good Luck.
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
KEv
KEv
If the solution offered by rdanz doesn’t work out you might try this-
Removing Oxidation or scratches from Vehicle headlights, Brake lights (polycarbonate)
Most vehicles now have a protective, transparent, plastic lens covering the headlights to protect expensive lamps (headlight assemblies range from 500-$700+) from flying stones and road debris. They discolour over time, becoming opaque and cloudy, these lenses can severely restrict the amount of light reaching the road.
This clouding is caused by accumulated exposure to ultraviolet light. If you live in a southern state, this discoloration can become noticeable in as little as two-years
Methodology:
·Use a solvent type cleaner (Klasse All-In-One) if this does not remove the oxidation use a plastic polish Meguiar’s PlastX or Renovo Plastic Cleaner
·Plastic Cleaners can be used to clean and condition Perspex as well as flexible plastic but is not suitable for use on glass.
·Prior to application of a plastic polish ensure that the window is clean and free from dust particles by washing with a soft cloth and warm water.
·It is not advisable to use cleaning detergents on plastic.
·Shake the bottle thoroughly. Plastic polish can be hand or machine applied
·Using a random orbital buffer with a 3.5-inch backing plate and a 4-inch (LC White) polishing pad or a terry cloth applicator
·Place a small dab (about ½-inch) of plastic polish on the foam pad or applicator.
·Place the pad on the lens surface and turn on the machine (speed #4)
·Polish the lens repeatedly in a left-to-right and an up and down pattern.
·Continue polishing until all the polish is gone
·Wipe the lens with a damp Microfiber towel
·Inspect the lens, repeat the polishing process if necessary
·Plastic polish will not remove clarity defects that are within the plastic but it will remove external/surface scratching and oxidation (yellowing)
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
