Mobil 1 ESP Formula M 5W-40 229.51
Old Apr 21, 2006 | 10:31 AM
Wolfgang's Avatar
MBs
This new oil for diesel engines with particle filter should become available in the USA on May 15.
Old Apr 21, 2006 | 03:00 PM
H-townbenzoboy's Avatar
1981 300SD TurboDiesel, 1982 300D TurboDiesel
Is this the oil that's being repackaged as Mobil 1 5W-40 Turbodiesel oil?
Old Apr 21, 2006 | 08:36 PM
Wolfgang's Avatar
MBs
The above is a different oil although with the same viscosity but has no MB approvals.
The new Mobil 1 ESP Formula M 5W-40 is a new oil and not yet available anywhere as far as I can tell. It's a "longlife low SAPS oil", low in sulfated ash and phosphorus and also with low vapor pressure so it wont pollute the exhaust particle filter. It extends the oil service interval to 20,000 km / 12,500 mi. It complies with the new MB oil recommendation 229.51 which should be printed on the can so one can differentiate it. It's probably based on Mobil 1 0W-40 or Mobil 1 0W-40 Turbodiesel, both of which have 229.3 and 229.5 approvals.
Some more oil stuff is here:
http://www.whnet.com/4x4/oil.html
Old Apr 21, 2006 | 08:43 PM
Wolfgang's Avatar
MBs
The W164 and W251 are also approved for this oil:
Old Apr 22, 2006 | 10:48 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Is there an advantage to using this oil over delvac if I have a 2005?
Old Apr 22, 2006 | 03:25 PM
Wolfgang's Avatar
MBs
Mobil Delvac 1 5W-40 228.5 should be fine, although formulated a bit different for commercial diesel trucks. There's now also a Delvac low SAPS oil for those commercial trucks with Bluetec. It's the new Mobil Delvac XHP LE Extra 10W-40 228.51.
Old Apr 22, 2006 | 08:27 PM
So for the old OM617s running synthetic, Mobil 1 Turbodiesel 5W-40 is just fine, the new oil is for the newer diesels right?
Old Apr 23, 2006 | 11:42 AM
Wolfgang's Avatar
MBs
Exactly.
Old Apr 24, 2006 | 03:05 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Oil
My feeling is that if you change your oil at intervals of around 3-5000, you don't need the special properties of the newer long life oils. Only if you want to run the interval change to the limit, do you need these oils. Just a gut feeling. No proof. Running Mobil 5-40 Delvac. Oil and MB filter change at 5000 mile intervals. Do it myself, using a Liquidynamics Oil Evacuator.
