Amsoil reformulates their "Gold Standard" diesel oil!!!!!
#51
My information below shows that Amsoil European Formula 5w 40 is MB Approved .
MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with exhaust particulate filters, and gasoline engines, and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Anglomoil RoadMaster 500 API SM 10W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Aral SuperTronic Diesel 229.51 0W-40 LOW SAPS
Bizol New Generation SAE 5W-30 (added 09 July 2007)
Castrol EDGE Formula RS SAE 0W-40 (added 09 July 2007)
Castrol EDGE Turbodiesel SAE 0W-30 (added 09 July 2007)
Castrol Longtec Turbodiesel 0W-30 (229.51)
ELF Solaris LSX 5W-30
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
megol Motorenoel New Generation SAE 5W-30
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 15 May 2006)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from December 2005)
OMV BIXXOL special C3 SAE 5W-30 (added 09 July 2007)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Sunoco Synturo Xenon SAE 5W30 (added 09 July 2007)
Valvoline SynPower MST 5W-30 229.51 (added 01 June 2006)
BMW recommends Castrol.
MB sheet 229.31 approved oils; LA "low ash" Oils
Mercedes pioneered this new spec for passenger cars with diesel engines with exhaust particulate filters, e.g. W211 E200 CDI, E220 CDI. The spec was introduced 7/2003. They are called LA "low ash" or "low SAPS" oils, low on sulfated ash, phosphorus and sulphur to limit exhaust particulate filter pollution. In 2004 the ACEA introduced the new C3 spec (mid SAPS, normal viscosity) based on it. Change intervals extend to 15,000 km.
30
Aral Tronic 229.31 5W-30
BP Visco 5000 MB 5W-30
Castrol FORMULA SLX Turbo Diesel 0W-30
Castrol TXT Softec MB 5W-30
Fuchs Titan GT 1 5W-30
Liqui Moly TopTec 7000 LA
Low SPAsh Motorenöl 5W-30 (DaimlerChrysler)
Midland Synqron 5W-30
Mobil SHC Formula LA 5W-30
Mobil 1 ESP Formula 5W-30 (from 3/2005)
Q8 Formula Special 5W-30
Pento High Performance 5W-30 LA
Shell Helix Diesel Ultra AE 5W-30
Shell Helix Ultra AE 5W-30
Wintershall ViVA 1 topsynth alpha LA 5W-30
40
Aral SuperTronic 0W-40 LOW SAPS (ACEA C3)
Castrol GTD Magnatec 5W-40
Fuchs Titan GT 1 10W-40
Liqui Moly TOP TEC 4100 5W-40
Midland Synqron 5W-40
Motor Gold Mid SAPS 5W-40
Motul SAE 5W-40 Vollsynthetisch
Pento High Performance 5W-40 LA
30
40
#52
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
However, thanks for posting thier warranty guidelines to show its hardly a "Gimmick", LOL
If you're not worried about it being the oils fault, where does that leave your deflated "argument"?
