Power box for CDI
Old 04-29-2010, 11:11 AM
Turbo M3's Avatar
Power box for CDI
which diesel power box would you recommend?
Old 04-30-2010, 02:14 PM
zemun1234's Avatar
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
I am using Kleeman KD box on my R320 CDI...It's OK but it was much better on my E320 CDI...
I think Brabus D6 box is good but very expensive (3x Kleeman). In my opinion, whetever you buy (except Brabus) is more/less same (~25 HP + 70 NM torque)
I am selling my car and I am going probably go with Brabus or ECU programming for next car ...If you are interested in for buying Kleeman box, let me know ...
Old 05-08-2010, 10:49 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Power boxes are very poor solutions. All they do is crank up the fuel rail pressure and injector duration, bad for the engine and the very expensive fuel system parts.
By far the best option is to reprogram the ECU. That way the computer actually has control and accurate feedback over what the engine is doing.
Old 05-09-2010, 11:47 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
I read the same elsewhere. What reputable company would you recommend? Tikkui suggested that reprogramming the ECU can also electronically delete the EGR function without actually doing anything to the hardware (no block off plates, no removal of EGR). At least that is my reading of his explanation.
Old 06-02-2010, 07:25 PM
jditom's Avatar
98 C43
This unit is the same as the Kleemann, I have them both and they don't increase fuel rail pressure.
http://www.upscaleauto.com/how_it_works.htm
http://www.upscaleauto.com/sprinter_...odule_chip.htm
Old 06-03-2010, 07:56 AM
240D 3.0T's Avatar
Then all they can do is crank up duration.
Old 09-16-2010, 08:51 PM
2slowcdi's Avatar
2006 E320 CDI 235 hp 420 ft tq
I have used Upsolute for 7 years in a 2003 VW TDI and 140,000 miles never gave me a problem.
So this weekend my 06 CDI is getting the ECU remapped.
I had my ECU for my Land Rover remapped by a company in the UK.
So I'm for remapping the ECU not changing the input so the ECU adjust to correct
what it thinks is going on,
the ECU can adjust everything then.
Old 09-17-2010, 11:42 PM
harkgar's Avatar
Are you located in the USA or UK? If the former where did you go for the ECU re-mapping and what is the cost?
Old 09-18-2010, 12:34 AM
majesty78's Avatar
MB 320 CDI OM613
Thats only half the truth*g*
I am absolutely no fan of those boxes and would prefer an ecu tuning in any case, but atleast the boxes from Carlsson do a little more.
They also fool the ambient pressure sensor to raise boost, to keep lambda at an acceptable level.
In generell those higher priced boxes have a little more insider than just an resistor to fool the fuel temperature sensor, most of them have some kind of microprocessor in them to manipulate duration.
Carlsson also clains that their box can also advance SOI, unless I dont understand how an additional box which needs initial injection signal from ecu could do this....
I dont know how those other boxes from kleeman or brabus work, nontheless I would never buy either one of them...
Regards, Alex
Old 09-18-2010, 07:40 PM
2slowcdi's Avatar
I live in US had my VW TDI re-mapped by Upsolute $350 as I recall USD that was back in 2004.
Today I had my 2006 E320 CDI re-mapped by Upsolute the cost
was $425 USD.
My Land Rover ECU was sent to R.P.I. in the UK to have them give
the ECU to Mark Adams at Tornado to re-map it, that was about
$1744 USD.
$1385 was just for the re-mapping the rest was import tax, shipping
HomeLand Security Bureau of Customs & Border got their cut too.
www.upsolute.com is in Austria they have dealers world wide.
Old 09-18-2010, 07:48 PM
240D 3.0T's Avatar
$1385 for an ECU remap? Did they give you a brick of coke with it?
Old 09-18-2010, 08:06 PM
majesty78's Avatar
MB 320 CDI OM613
Lol, you're funny Forced *g*
AFAIK upsolute is more an buy / resell type of chiptuning company, I dont know if or which ecu's they are realy specialized on and which of them they realy program theirself.
Anyway, if you see a company offering chiptuning for all carsten from A-Z you should realize that it is nearby impossible to write all of those mappings by yourself, if done properly....
So in fact there are 2 possibilitys:
They write everything by themself, and to achieve this, only the absolute neccesary changes are done (maybe thats why they are called upsolute *g) or
They work together with other companys to inquire software they not program by themselfs...
Who knows....
Regards, Alex
Old 09-19-2010, 11:33 PM
harkgar's Avatar
was $425 USD.
$1744 USD.
Thanks for the quick reply. I e mail the local Upsolute guy and his price is similar to yours. The re-mapped power claims are very moderate so he is honest.
Old 09-20-2010, 06:36 AM
2slowcdi's Avatar
I have found Upsolute to be what the OEM settings should have been from
the start.
Have a Good Day.
Quick Reply: Power box for CDI
