RaceChip tuning. Please share your experience.
Hello Diesel owners.
Does anybody have experience of using RaceChip on diesel engine ? Can you share it ? I'd like to buy it for my 2015 GL350. Does it really worth it ? Is there any noticeable power and MPG improvement ? Here is the link : http://www.racechip-usa.com/chiptuni...S-Spec)-179kw/ Thank you. |
just put one in today...so far nice upgrade but i am getting egr code 490 and researching that to see if it is related
ok p0490 code is related.
i turned it up too far the company said that is what happens when you reach limit of the chip/car so i turned it down and problem went away too soon to tell about the mileage claims though Steve |
So is there any updates on this thread? Is this a good product or snake oil?
Sideout... the chip so far is working very well,
i am still turning it up for more power , it requires turning it up then driving for a while to make sure no check engine lights so its a slow process big power increase and my dash mpg meter is recording about 2 mpg increase overall so far very nice upgrade still playing with the settings Steve |
racechip experience
I installed the Racechip about 4k miles ago. Overall experience has been OK. You can notice the increased torque and HP when you punch it from a stop. Most of my driving is highway type and either I have gotten use to it or not, I have forgotten its there.
My computer says my MPG went up but not sure that translates into actual or not. Measuring at the pump isnt as consistent as gas due to the diesel foaming etc. Installation is straight forward and simple. Take a little time to route properly and you cant notice anything was ever changed. Overall its an OK upgrade for not a lot of $$$. I would do it again. |
Thank you for the update. Which model have you bought ? They keep telling me that only Ultimate ( the one that cost $599) is good for 2014 and up.
i had to turn mine down because of check engine lights namely egr current high
the company said this is the chip at its limit so i turned it down till check engine lights stopped coming on and now the power increase is not as much as i like not seeing much fuel mileage changes since i turned it down which thought it would go up seeing i turned the chip down i dunno, kinda confused with it Steve |
might want to look at the digiC2A two channel
it does boost and rail pressures http://www.parleysdieselperformance....nz-turbodiesel |
Originally Posted by fireman1073
(Post 6548490)
it does boost and rail pressures http://www.parleysdieselperformance....nz-turbodiesel I am using Kleeman KD Box for some many years (on different cars) and I am very satisfied with performance. |
Originally Posted by zemun1234
(Post 6576602)
I think it is same as Kleeman - it was some dispute between DieselPower and Kleeman who is owner of patent but in general it is working on same way.
