Periods of very loud rockers OM642 then turbo shut down.
I don't remember if $4 OBD plug will give you boost pressure, but $150 iCarsoft definitely will.
Knowing total mileage and mileage since EGR and intake flaps cleaning could help us in guessing.
The car has 135K miles.
Just did the tune with deletes last week.
I cleaned the EGR but not the intake flaps.
I say the turbo shuts down as in electroically not adjusting the fins, not seized because the car loses maybe 80 percent of its power and acts like it's a very small engine. It drives fine but has very little pickup. If doing 65 it will maintain 65 but bearly accelerate. I have an Actron Auto Scanner CP91865 and I am working on how to get readings for the turbo boost.
One more point of drivability is that at almost any acceleration level the power is not smooth. It surges more and less throughout the RPM range. But is smooth at a steady cruise.
I have checked all 3 times it did it and there were no codes or pending codes.
I rebuild turbo on this engine at 180k miles while doing other jobs and there was nothing wrong with the turbo.
Meaning I would not expect the fins to get that much carbon to freeze them at your lower mileage,
Than you never know.
All the same problems persist. No codes or pending codes on the ICarsoft MBII.
But almost daily the turbo stops working after an acceleration where I can hear the engine diesel sound clearly louder. Then acceleration power drops down dramatically.
Regular acceleration is not smooth but has slight to moderate surging.
Transmission 1 to 3 shifts are smooth half the time and the other half the time abrupt.
When I come to a full stop, 1 to 2 seconds later the engine stumbles loosing 150 RPM or so then over compensates and surges momentarily. If I am not at a firm brake pressure, it actually moves the car.
I'm thinking it's time for a Starr diagnostics. Any ideas?
So I wouldn look for something that reduces your torque. Or would trigger a limp mode if that what it feels like.
