Click clamps
Also, the hoses appear to be different sizes. FCP Euro lists one clamp, pn. 0049972090, 14.5-15.5mm. Does it fit both hoses?
TIA
TIA
https://www.idparts.com/fuel-filter-...01-p-4402.html
TIA
It worked, but opening used clamps without damage took some time. I am retired, so my time has not much value, but when you make more than minimal wage and calculate the time to money, you will be better buying new, not even talking about risk involved in reusing old clamps.
Fuel line hose clamps for OM648
Return line 0049972090 (14.5-15.5mm)
Supply line 0069971890 (13.0-14.5mm)
it can be tricky releasing them, I use a skinny ICON pick, from Harbor Freight and you need special pliers putting them on. Far superior to the worm drive type clamp. I don’t reuse because they are cheap enough.
Different brand, but same idea:
The clamps used on PEX tubing and the ones you linked to above are also called Oetiker clamps and are definitely one time use only.
they get heated and cooled a bunch.
the force these (as well as oetiker) clamps exert is engineered. It’s not random like a screw clamp.
