2010 E550 coupe does anyone know how to remove the interior bulbs
Old Mar 3, 2012 | 11:36 PM
Acworld34's Avatar
2010 E550 coupe
What is the easiest way without breaking anything?
has anyone doen it on here?
I ordered all the LED bulbs and now i want to repalce all of the interior lights?
Old Mar 4, 2012 | 01:53 AM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
This:
https://mbworld.org/forums/c-class-c...-pictures.html
and this:
https://mbworld.org/forums/c-class-w...t-removal.html
The first one is the easiest ones using the credit card without any damages for the front and rear dome housings. The second is good reference for removing all those vanity, trunk, doors and footwell housings.
So, what you need are just a credit card and a screwdriver to remove everything.
Old Mar 4, 2012 | 10:22 PM
Acworld34's Avatar
2010 E550 coupe
Originally Posted by Ultraman
This:
and this:
Thanks This helps alot !!!
Old Mar 4, 2012 | 10:51 PM
dsayed's Avatar
2010 E550 coupe
This video might be useful too...
Old Mar 4, 2012 | 10:54 PM
Ultraman's Avatar
Just a friendly reminder in case you want to switch led conversions to your halogen ones. This is the most time consuming mod. You have to take out those push pins behind the trunk lining with either a screw driver (chance of 90% damage the pins) or use the interior trim removal tool (recommended to use the plastic ones with 10% damage the pins).
BTW, what kind of bulbs do you use for the front and rear domes? I was using those 12SMD panels. They were bright.
Anyway, happy LED modding.
Old Mar 4, 2012 | 10:56 PM
Ultraman's Avatar
http://www.youtube.com/watch?v=Wx3M8yRvcus
The W212 or C201 Mercedes overhead dome lights are similar to the W204.
The links that I mentioned before are safe and much more easier and faster to swap out the bulbs.
Old Jul 31, 2014 | 03:15 PM
D0N0VAN's Avatar
2010 E550 Coupe
Where did you find the LED interior set for sale?
Old Jul 31, 2014 | 03:37 PM
dsayed's Avatar
2010 E550 coupe
I bought mine from ijdmtoy.com
Old Aug 1, 2014 | 09:12 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Harbor Freight sells a kit with several plastic interior trim removal tools.
Less than $10. Used mine quite a bit.
Old Aug 1, 2014 | 11:07 AM
Ultraman's Avatar
I still cannot figure out how to remove those 2 small map light bulbs under the rear view mirror since I owned the car.
