drivers door doesn't lock automaticlly
Old Jun 8, 2014 | 05:28 PM
muhaimma's Avatar
E350 2010
Hello,
i have noticed today on my E350 2010 that the automatic key lock doesn't lock all doors.
using the remote, it only locks the passenger's door. but doesn't lock the drivers door. i have tried the central lock (inside the car) but does the same issue.
i can lock and unlock the drivers door by the master key and manually with my hand when im inside the car.
im not sure what is the issue? is it a fuse? please note im not under warranty.
thanks,
Moe
Old Jun 8, 2014 | 08:55 PM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
Check out the settings in the center of your guage cluster. I forget the exact setting, but maybe it's in there.
Old Jun 9, 2014 | 01:57 AM
muhaimma's Avatar
E350 2010
Check for what?
Old Jun 9, 2014 | 11:56 AM
theraven333's Avatar
Mercedes E350 CD Iridium silver convertible 2010
First try changing the batteries in all key fobs!!!
Then check that you have the correct settings in the settings screen, do the doors lock when you drive off for example, check the convenience settings.
Old Jun 9, 2014 | 04:18 PM
muhaimma's Avatar
E350 2010
I had a diagnostic test on the vehicle and showed a fault
The MB object number for hardware is 212 820 37 26
Diagnosis identified is 000211
Fault 98b101 the output for the central locking motor has a malfunction there is a general electrical fault.
Old Jun 9, 2014 | 04:21 PM
muhaimma's Avatar
E350 2010
I wish i can post a photo
Old Jun 10, 2014 | 08:12 AM
Hi, at least you now know it is a fault and not a set up issue, first is to check fuses and simple wiring disconnects.
You mention that it does lock, manually, does it unlock electronically?
As I mentioned does it lock when you drive off???
You may have a door control module failure????
Old Jun 10, 2014 | 08:35 AM
muhaimma's Avatar
E350 2010
No it only locks manually (by hand). How can i check the fuses? Which fuse? I never opened up the fuse box.
Old Jun 10, 2014 | 01:21 PM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
looks like a door actuator failure to me if not 2 doors related ...
