E550 coupe. Problem with 20 inch wheels
Old 07-18-2014, 10:19 PM
Piterts's Avatar
Mercedes e550 coupe
Tires
245/30/20
275/30/20
Old 07-19-2014, 09:29 AM
MrH
MrH's Avatar
2010 E550 Coupe
Originally Posted by PC69
Can you post picture of your setup. I'm thinking of 20" wheel but want to keep stock spring. Most people say it doesn't look right with 20" wheel without lowering.
Most people actually assume it's been lowered. As long as you go with thicker tires to eliminate the wheel gaps it gives that illusion. I'll try to get some pics up soon (been meaning to anyway) and you can judge for yourself.
Old 09-16-2016, 01:00 PM
Logan214's Avatar
2013 E550 cabriolet
Hey folks, so I wanted to bring up this topic again. I recently bought a 2013 E550 cabriolet and bought 20" Euromags 2 for it . 20x8.5 45 front and 20x10 50 for rears with 245/35/20 fronts and 275/30/20 rears which seller said would fit fine. I just went to have them installed and fronts are hitting against struts and won't mount. Is it because offset is 45 and not 35 for fronts? Seller telling me a 5-8mm spacer should do the trick.
Thanks for help.
Scott
Old 09-17-2016, 01:10 AM
mo11's Avatar
2017 C43
Thanks for help.
Scott
Attachment 339629
its most likely the profile of the tires more than the offset. I have a '14, i don't think the struts are any different. But on my fronts i have 20x8.5 offset 42, the tires are 245/30 20, not 245/35 and i don't have any issues. It won't hurt to try those spacers either.
Hope this helps... good luck!
Logan214 (09-17-2016)
Old 09-17-2016, 10:13 AM
Logan214's Avatar
2013 E550 cabriolet
Thanks for the info and I'll pick up the new size tires as you recommend.
Old 09-18-2016, 06:08 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
+1 on the tyre size and not the offset. go 245/30/20 and youll be golden.
Logan214 (09-25-2016)
Old 09-18-2016, 07:45 PM
  #32
Logan214's Avatar
2013 E550 cabriolet
Thanks everyone for the recommendation to correct these. I'll order the 30 asap.
Old 09-25-2016, 08:11 PM
  #33
Logan214's Avatar
2013 E550 cabriolet
You guys were absolutely right. Installed the 245/30/20 on front today and they cleared the strut plate with no rubbing or banging after test ride. Thanks everyone, you guys rock!!!
Old 09-25-2016, 08:24 PM
  #34
beejAMG's Avatar
i wont take the credit for this but just glad to help.
your car looks awesome! time to post more pics!
Old 07-18-2017, 09:41 PM
  #35
Chrisgmt's Avatar
2015 S550 & 2012 E550 Convertible
2012 E550 Cabrio Help with upgrading wheels and tires
Thanks for the info on the wheels and tire sizes with offsets! I am about to go shopping for wheels for this car I just bought. Did anyone have any issues with the speedometer? Suspension, tire pressure monitors? The service guy at the dealer said I would have a lot of issues with these things. Also, with the stock 18" wheels and tires, I get a VERY stiff ride. Will the larger wheels and tires help with this too?
Quick Reply: E550 coupe. Problem with 20 inch wheels
