Removing water sprinkler stains from my black E550
Old Aug 2, 2014 | 12:29 AM
BBowles's Avatar
E550
We are having our kitchen remodeled so I parked my black '12 E550 in the cul-de-sac so the workers could come through the garage. While my E550 was parked outside my neighbor's sprinkling system came on and the droplets pretty much got baked on the E550. I washed it today by hand but that didn't completely remove the "stains". Can anyone recommend a product I can use to get those damn rings off?
TIA.........
Old Aug 2, 2014 | 02:18 PM
Caker's Avatar
C207
Clay bar should do the trick, then put a good polish or sealant on afterwards. Youtube has a bunch of good tutorials to show you how to clay your car
Old Aug 3, 2014 | 02:27 PM
msheredy's Avatar
MB
If the clay doesn't work try meguiars ultimate compound with an orbital polisher. That stuff is amazing.
Old Aug 4, 2014 | 10:46 AM
Kirkster's Avatar
2014 E550 Coupe
Same thing happened to me on my black infiniti. I found this stuff. http://www.3dproducts.com/eraser-onl...ver-16-oz-gel/
Takes the spots right off. No effort whatsoever. Follw the instructions..
Old Aug 4, 2014 | 04:18 PM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
I THINK the polish compounds are the least abrasive options, so I'd go with that. Rubbing compounds and clay bars though don't seem it, can more abrasive. Again, I'm actually not 100% sure on this so I'd read up on it. They all will do the job, but you want to use the least harsh one right?
Old Aug 12, 2014 | 12:24 PM
MCMike37's Avatar
2014 E350 Coupe
I have the same issue on my black Jeep, tried everything in the world to include water spot remover, vinegar, clay bar, etc. Nothing worked until I got down and dirty with a pad and Meguir's Polishing compound as mentioned above. Took a long time but worked fantastically, then bought a good high quality orbital polisher to finish the rest of the car.
Kicking myself because the best way to deal with them is a consistently good coat of wax to prevent the spots.
Old May 18, 2015 | 05:06 PM
lxi's Avatar
lxi
2012 E350 Cabrolet
Watch this
you can skip through the begining - its awesome - will solve all your problems
https://mbworld.org/forums/e-class-c...lack-e550.html
Old May 19, 2015 | 01:32 PM
msheredy's Avatar
MB
Originally Posted by lxi
Watch this
LOL your link directs back to this thread
Old May 19, 2015 | 02:39 PM
lxi's Avatar
lxi
2012 E350 Cabrolet
Oooops, my bad (had a lot going on). Here you go.
good luck.
Old May 19, 2015 | 05:35 PM
Need4Speed's Avatar
Former Vendor of MBWorld
2018 C63S
TIA.........
Use some Meguiars M205 Polish followed up by some Meguiars M21 sealant for long lasting protection.
Could be done by hand or DA.
