Will donor seat work?
C207
So after searching I found a seat that looks identical other than a minor stitching outline.
Before I purchase I want to ensure that the seat will fit. Mercedes said the seat should bolt on but some of the connectors may be different - they are not 100% sure.
Here is the donor WDDKJSHB5GF316568
Here is my vin
WDDKJ5GB3AF042421
If anyone can confirm please let me know!
Here is my vin
WDDKJ5GB3AF042421
Received 4,448 Likes
'71 Pinto
Donor VIN invalid. Current driver seat 2746, passenger 2846:
C207
its from a junkyard. Merecedles dealership could read the vin. Said the seat will bolt in but not sure if the control module needs to be rewired. Not sure what that means and if I should go ahead
I wonder why some people can’t access the vin.
'71 Pinto
One error WDDKJ S(should be 5) HB5GF316568
C207
'71 Pinto
You need to confirm full VIN I pointed 1 potential error others exist. When I have the correct VIN I will pull model year & codes on donor to see if seats match.
'71 Pinto
C207
'71 Pinto
Codes are in alignment including rear bench seat. Only difference I see is seat CU not sure if they can be swapped. Your vehicle left 2129005200 (code 275 memory package), right 2129005300 (242 electric adjustment w/memory switch); donor 1729006903 (275), 1729007003 (242). As far as I can tell seem to compare fine.
Left:
Right:
Left:
Right:
C207
Again, excuse any dumb questions.
I only have the driver's side seat to swap. What is Seat CU?
Computer Unit?
I know the leather is a little different. Donor has Nappa and has a solid stitching but i think that can work fine.
I think the seat will bolt in but will the connector work and all the settings? It's from a 2016 going in 2010
thanks so much!
Computer Unit?
thanks so much!
'71 Pinto
C207
THANKS for your help!!!
DO you know if i can swap this seat out myself? I know i need to reset the airbag. I have a carsoft tool can i do it with that?
Anyone have instructions on replacing the seat?
'71 Pinto
See attachments, just make sure you disconnect battery ground line.
'71 Pinto
Normally not but if donor seat needs it best to find someone with Xentry (MB diagnostics).
C207
OK, I give up! What the hell is a "donor seat"? I Googled the term and all I found was a chair to sit in while donating blood, which seems a bit odd for a car.
