adjust accelerator linkage on 1983 240d
W123 300CD, R107 560SL, W211 E320
Please be more specific. Is your top speed severely limited or is your acceleration very slow? Are you sure that you are not simply experiencing normal 240D doggie performance.
Has the linkage been modified/adjusted/messed with before? If not, it probably does not need adjustment now. The throttle linkage as came from the factory is a lifetime thing except for occasional lubing of the joints. Your "speed" problem may be due to other issues, usually fuel problems.
1983 Mercedes 240D
My top speed is very limited. With pedal to the floor I can just get to 55 mph on flat road. Acceleration is ok. Several years ago a Mercedes mechanic replaced a piece that was plastic and had worn out. It was at top of engine.
1983 Mercedes 240D
adjust accelerator linkage on 1983 240d - FIXED
I took another look under hood and there was loose plastic piece in the firewall where rod from accelerator would rotate in. I pushed that piece back in firewall and got it tight and took the car for a ride. Much better.
Your part number is 123 300 13 40 M22. It is called "accelerator pivot" and costs about $55. Available on the Pelican Parts and autohausaz web sites as well as some others. View it to make sure we are talking about the same part. Also plenty on ebay.
Please give us a status report when repaired. It helps others.
