Replacing coolant please help-
Old Jan 25, 2006 | 01:29 AM
Hopeless's Avatar
Hi Everyone-
I just replaced the radiator on my 89 300E, and now i need to fill the radiator with coolant, however, there is no cap on the radiator, so how do i fill it?
Old Jan 25, 2006 | 03:04 AM
neanderthal's Avatar
over flow bottle/ expansin tank, right side of car, behind the windshield washer bottle.
Old Jan 25, 2006 | 03:42 AM
Hopeless's Avatar
that seems to be the thing to do, but will it fill the radiator? Do i have to have the engin running? I was under the impression that it was some sort of vaccuum system and it only supplied a bit extra for the radiator when it was needed. I was going to try to pour coolant down one of the hoses before they were attatched to the water pump, but that didnt seem like a really good idea.
Thank you
Old Jan 25, 2006 | 04:04 AM
NorCal124's Avatar
W124
as long as you have the hoses hooked up correctly then you're ok. just open the cap and pour until you reach the max line.
Old Jan 25, 2006 | 06:49 AM
Silvo's Avatar
1995-E320 Coupe
to avoid air bubbles remove the upper hose from the radiator while engine is idle and wait till you see no air.
Old Jan 25, 2006 | 01:01 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
If refilling through the expansion tank doesn't work, you can refill through the thermostat housing.
Old Jan 25, 2006 | 09:25 PM
lkchris's Avatar
'10 CL550, '12 GL550
Refill plug in front left side of cylinder head as well. Use new washer.
Old Jan 25, 2006 | 10:26 PM
you could also park the car with front wheels up on a driveway/ curb or something, the bubbles/ air will gravitate towards the highest point.
