18 inch rim question...
Old Feb 20, 2006 | 08:30 AM
shadowgriffen's Avatar
is a German Tank
hey guys, I'm currently rim shoping for my TE
well I bumped into this great deal on some 18 rims...well the question I had is
1. I have no suspension mods (stock ride)
2. Should I do 18's or stick with the original plan of 17's?
3. And most importantly will this fit - 225/40 with an ET of 33 (Weird, ET 33 just sounds strange to me...dunno why ) ?
thanks guys, your imput will be make my decision easier.
Old Feb 20, 2006 | 08:37 AM
is a German Tank
damn it sorry Mods...why do I always double post when I edit???? :sigh:
Old Feb 20, 2006 | 09:24 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
The ET has to do with the rim dimensions, nothing with tires. More important if the 18" will fit is the rim width in coparison with the original 17". The ET-dimension is the offset (in millimeter) of the mounting plane of the rims. So for example if the originals have ET39 the 18" (ET33) will stick further out by 6mm (~1/4") The next step is to calculate the new circumference of the wheel to avoid the odo/speedometer reading is too far off. (~ 5% is okay)
arthmetic:
circumference (C): Diameter of the rim (18") plus 2*(hight of the tire shoulder=225mm*0.40) *3.14.
18"=457.2mm; hight of tire = 90mm
C=(457.2mm + 2*90mm)*3,14 = 2000.8mm. Compare this value with the current tire/rim you are driving and the result shall be between 1900 and 2100mm
Old Feb 20, 2006 | 09:32 AM
is a German Tank
hmmm...ok so you're basically saying that I shouldnt have any problems correct?
Old Feb 20, 2006 | 10:00 AM
What I was saying is that you need to make a few calculations to check the differences between the current geometry and the new, to figure out if the new wheles will fit into the wheel well and the odo/speedo readings are within an acceptable tolerance. The ET of the current rims is normally stamped on the inside of rims.
Old Feb 20, 2006 | 10:39 AM
is a German Tank
gotcha! i'll check them out, I'm riding on stock 15 holes
Old Feb 20, 2006 | 01:43 PM
2PHAST's Avatar
500E Signal Rot
The lower the offset, the further out the wheels will get (towards fender lip), so +25mm offset is really close to the fender lip (well, on my car at least) and a +35mm offset insets the wheel more. Too much positive offset and you will have inner rubbing problems, not enough and your wheels will either stick out or rub your fender lips and/or bumper lips.
Old Feb 20, 2006 | 09:58 PM
YNVDIZW124's Avatar
lots of cars
im going with 18x8 35 offset and 225/40/18 also make sure the hub is 66.6 or get hub centric rings.
Old Feb 21, 2006 | 10:58 AM
is a German Tank
that couldn't have been said better, Thanks a million!
Old Feb 21, 2006 | 01:34 PM
YNVDIZW124's Avatar
lots of cars
The 500E has a different offset than a 300E, CE, and TE. +25mm offset is going to stick way out on the fender unless you like the low rider look. The correct offset is +38mm but you can go between +35mm and +40mm depending on the width of the wheel. You can run as low as +30mm but you will need to roll the fenders and use fender spacers. Those 500E guys can run any mercedes 19 and below wheels they want! I envy them for that!!!!
Old Feb 21, 2006 | 02:49 PM
is a German Tank
I envy them for owning one period...
