94-95 US headlamps compared to euros
Old Apr 6, 2006 | 12:01 PM
jas2wa's Avatar
1994 E320
Hello-
The 3 month old replacement headlight assembly just took a rock on the highway last week, and its glass lens is now pretty cracked, I'm just waiting for it to get tapped and fall apart...
My question is this- on the later 94-95 124s with the modified hood/grille/headlamp configuration, is there any difference between the US and euro set-ups for those years? I know the 86-93 US 124s have an inferior set-up to the euro versions, but the last 2 years of the US cars appear to be indistinguishable from their euro counterparts- is that correct?
It seems that the glass lens is not available, and I must buy the whole headlight assembly- that said, I want to explore whether or not I should look into going euro with the replacement(s)- the US spec assembly is not cheap!
Here's a pic, my car in front, US spec 94 E320, and a 91 124 US car w/ euro lights behind it-
Thanks and cheers,
JAS
Old Apr 6, 2006 | 04:38 PM
Eliot's Avatar
Range Rover Classic
I believe cosmetically they're the same. You could go for the E500 Euros which have a second driving light instead of a fog lamp.
Old Apr 6, 2006 | 07:18 PM
neanderthal's Avatar
i think there is still a difference between the actual housngs and the lenses. the glass looks the same, but i think its slightly different.
i could be wrong.
Old Apr 7, 2006 | 01:51 AM
Holson's Avatar
18 G550, 24 EQB3504M
The lens is slightly different...
check it out
http://www.w124performance.com/images/W124_headlights/
http://www.w124performance.com/image...eadlights4.jpg
I am planning on getting a pair of Euro headlights for my E420 actually. But that's if I'm keeping the car
Old Apr 7, 2006 | 09:46 AM
jas2wa's Avatar
1994 E320
In those pictures, the later 94/95 style lamps fit in the 93 and earlier body, but you can see where the hood design of that later cars should cover part of the lens- interesting. Didn't know you could put the later style in the 93 and earlier cars.
That said, those pictures show the lens seperated from the assembly- can I get the glass lens? I've been told no by one parts supplier.
Cheers,
J
Old Apr 7, 2006 | 12:35 PM
NorCal124's Avatar
W124
You can use them but they won't match your hood. Thats why some people choose to do the "face lift" and purchase a newer style hood along w/ the lights.
Old Apr 7, 2006 | 03:05 PM
Holson's Avatar
94+ US-Spec Non E500 lenses:
http://cgi.ebay.com/ebaymotors/Merce...53209212QQrdZ1
http://cgi.ebay.com/ebaymotors/Merce...53241215QQrdZ1
They sure aren't cheap ...
94+ US-Spec headlights
http://cgi.ebay.com/OEM-Mercedes-W12...QQcmdZViewItem
No idea where to get the Euro-spec ones...
Old Apr 10, 2006 | 07:15 PM
AMGDave's Avatar
300D, 500E, E420
I've got a set of brand-new 94/95 Euro lenses for sale at the moment, for a lot less than the eBay stuff:
https://mbworld.org/forums/classifieds/140558-fs-w124-euro-light-lenses-new-box.html
The light pattern from the Euro lenses is slightly different (and better, IMO) but they are very, very close in performance to the 94/95 USA DOT lights. The Euro lenses should fit a 94/95 USA DOT housing. The 94/95 headlights after a certain VIN have the lenses bonded (glued) to the light due to some insipid DOT regulation, making them a pain to remove. I've heard if you put the assembly into an oven on low heat for a while it softens the glue and the lens pries off with a little coaxing. If you're lucky, your 1994 lights may not be bonded... my 1994 E500 didn't have the lenses bonded.
Old Apr 14, 2006 | 11:21 AM
jas2wa's Avatar
1994 E320
AMGDave-
I imagine the lenses should fit on my US headlamp housings- the euro and US versions are so similar on the 94/95 that I can't imagine they would mount differently.
I'll send you a pm-
JAS
