Radio Help
Old Jun 5, 2006 | 01:17 PM
speedracervroom's Avatar
300E
Radio Help
Ok so i just got this 86 E300 and i have been trying to get the radio to work i searched and searched and notthing with my problems came up. so here whats wrong and what i found out i figured out what wire is what and what has a postive feed so i pulled the radio out and checked the fuse in the back (it was blown) so i go ad buy another one and still didnt come on i check the fuses under the hood still good but i replaced that one as well . so i checked the volts on the wires red gave me a 12V charge purple did not?? black and yellow did. so i ran a hot wire to the purple thinking that would fix it. it lit up where the tape goes but notthing else??? and while i had this hot wire i connected to the atenna that plugs in the radio and the attenna worked finally so im out of ideas what it could be any advise would help thanks.
Old Jun 7, 2006 | 01:42 AM
300E
any one know the fuse size on the back of the radio???
Old Jun 7, 2006 | 10:47 AM
Smokiesman's Avatar
93 300SE Rauch "Smoke"
I don't know for sure ! But most of the radios I have installed are about 5amps!
Smokie
Old Jun 7, 2006 | 11:37 AM
300E
well i think the fuse says T5/250V or is it 15/250V??? the fuse i got for it is 5/250V just making sure its the right one.
Old Jun 8, 2006 | 03:13 PM
300E
dose anyone have a pic of the back of the radio and connections i think im missing some wires?? not the plug with the red, purple ect. on top right the other one it only has one wire Brown is that how it is lmk thanx
