HL wipers help
Old Jun 12, 2006 | 10:49 AM
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
HL wipers help
Ok i had the car for a long time now and i noticed that my headlight wipers doesn't work. Is there a switch somewhere the makes it work somewhere? or is it my motor is just out?
Old Jun 12, 2006 | 12:43 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
First verify the problem. They should ONLY work with the headlights on AND the windshield wipers on AND (I believe) the washer system activated.
Old Jun 12, 2006 | 02:52 PM
Ok so im guessing its the motor...? Whenever i turn on my wipers the HL wipers doesn't work. What is that telling me?
Old Jun 12, 2006 | 05:13 PM
battlecat714's Avatar
a TVR Cerbera Speed Twelve
bad motor
Old Jun 12, 2006 | 06:22 PM
ZedStyle's Avatar
Youngtimer
he said they come on with headlights on, wipers on, AND your washer fluid... get someone to sit in your car, put the lights and wipers on, and hit the washer fuid, and see if they move...
Old Jun 12, 2006 | 07:10 PM
No. The HL wipers doesn't work period. =\ So therefor i need 2 motors?
Old Jun 12, 2006 | 10:57 PM
Makahveli's Avatar
"88 300CE- First Year Production
Yeah mine only work when squirting out washer fluid, so does fluid come out of these too?
Old Jun 13, 2006 | 08:45 AM
Kestas's Avatar
Maybe, but doubtful. I find it hard to believe both motors went out at the same time. The challenge now is to bracket the problem. Is there power going to the motors?
You'll have to get a wiring diagram and figure out where the problem may be. I believe the system has a control module, and that module may have bit the dust.
Old Jun 13, 2006 | 10:34 AM
So i should see if the control module is dirty or just loose somewhere?
Old Jun 13, 2006 | 04:25 PM
Kestas's Avatar
Yes, that would be the quick thing to do before doing formal diagnostics.
