Electrical Problem
Old Nov 13, 2006 | 10:05 AM
cml55's Avatar
Question Electrical Problem
I have a 94 E-320 Wagon. Yesterday the gauges all went to zero and the combo relay(Wiper , turn signals)started to buzz real loud. When I tried to start the car the started would not engage. I used a remote starter switch and the car started and ran fine but still no gauges and the realy still buzzed. The signals wipers etc did not work. Several of the fuses tested show no power but when I bypass the fuse still nothing works. I also had a spare relay which worked off and on. I put it in and I still had the same problem and the loud buzzing.
The wiring harnes is good and I the wires to the starter are new.
I did a search and could not find anyone with the same problem. I am going to get a new combo relay but I am open to any other suggestions.
Old Nov 13, 2006 | 11:50 AM
mgw_300e's Avatar
Dora the Explorer
Have you ever swapped your fuses out from the originals? The dissimilar metals in the stock fuses/fuse box leads to corrosion and can create electrical problems. Check out mercedesshop.com for a kit.
Also, sometimes the fuses can be blown because of hairline cracks that are hard to see. I would suggest pulling them out and looking very closely.
Maybe the switch itself is bad.
Just a few thoughts for you.
Old Nov 13, 2006 | 02:19 PM
cml55's Avatar
Smile
Matt,
Thanks for the advise. I went home and went through the fuses again and #5 was bad although it looked fine. As soon as I replaced it everything went back to normal. I will go ahead and replace them all. This message board is great.
Old Nov 13, 2006 | 02:53 PM
mgw_300e's Avatar
Dora the Explorer
glad to help!
Old Nov 13, 2006 | 03:08 PM
Bigpete123's Avatar
1990 300ce
Man, I wish my car problems were that easy to solve!!! just a dollar or so for a fuse. very nice.
Old Nov 13, 2006 | 08:05 PM
cml55's Avatar
If it will make you feel better I did spend $10 as I replaced all of the fuses
Old Nov 13, 2006 | 09:12 PM
Bigpete123's Avatar
1990 300ce
ha ha, nice! I'm glad this was so easy.
Old Nov 14, 2006 | 10:59 AM
'91 300CE's Avatar
2000 C230K and 2002 ML320
I JUST changed all my fuses on Sunday after a few electrical issues... my god, what a difference... I can lock my doors without my stereo amps cutting out and making my dome light/seatbelt lights flash... AND my Climate Control doesn't click and do weird things... I am HAPPY!!!!!
Old Nov 14, 2006 | 12:03 PM
shadowgriffen's Avatar
is a German Tank
Way to go Matt!
Old Nov 14, 2006 | 02:22 PM
mgw_300e's Avatar
Dora the Explorer
Originally Posted by shadowgriffen
Way to go Matt!
Hey, you've got your OVP, I've got my fuses.
Old Nov 14, 2006 | 03:01 PM
is a German Tank
haha! I've ordered a set, thanks alot LOL
Old Nov 14, 2006 | 03:06 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Stay teh away from teh plats!
Old Nov 14, 2006 | 03:25 PM
mgw_300e's Avatar
Dora the Explorer
hwta rea uoy sainyg?
Old Nov 14, 2006 | 03:27 PM
1990 300ce 24v I6
Smartass, Im saying stay the **** away from the Bosh Platinums.
