Middle vents dont work?
Old Nov 18, 2007 | 06:32 PM
watut's Avatar
1995 E320 Cabriolet
I tried all the settings on the heater and the middle vents dont seem to want to work, all other ones do. It's a 91 300e
Old Nov 18, 2007 | 07:21 PM
jlink38's Avatar
E320
They're really only used for A/C... I thought mine were broken too but it is completely normal for them not to work using heat.
Old Nov 18, 2007 | 07:27 PM
ZorroAMG's Avatar
Enzo, my Benzo
Quoted for truth!
Old Nov 18, 2007 | 07:39 PM
jmoney6's Avatar
1993 Mercedes 300e 4-matic (m103 motor)
The middle vents dont come on with heat I tink because mercedes doesn;t want oyu falling alseep at the wheel, however they will blo heat if the outside temperture is extremely cold.
Old Nov 19, 2007 | 07:32 PM
AMGDave's Avatar
300D, 500E, E420
The center vents only blow cool air. You will never get heat out of them. However it is very common for one or more of the vacuum pods that control the vents to fail after 10-15 years. Here's a link with details on how to test all of them - you just need to pull the glovebox (or passenger airbag), and use a Mity-Vac:
http://www.buymbparts.com/forum/showthread.php?t=528
More photos are here:
http://www.w124performance.com/images/W124_dash/
Old Mar 6, 2008 | 11:38 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Hate to bump, but I was concerned tonight since my middle 2 vents werent putting out heat that something had broken. Well, this answered that and saved my ****, so thanks guys!
Old Mar 7, 2008 | 03:16 AM
X03's Avatar
X03
MB 1990 300E
unfortunately my center vents don't even blow cold! only my defroster and side vents work. i need to do the diy check on it sometime but its just been too busy...
on another note, does our A/C blow softer or harder depending on how much your on the gas? If i set the a/c on the lowest setting, it will still blow harder if I am stopped at a light with my foot off the gas then when I am just accelerating. only reason I ask is because it used to blow at one speed/setting no matter what. now it constantly fluctuates depending on the gas pedal.
Old Mar 7, 2008 | 10:50 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
I can't think what would cause that. The fan speed should modulate slowly with temp only. It may run slightly slower when stopped and idling due to decreased voltage, but I think it even compensates for that.
Also FYI, when you roll the temp knob all the way to the end of its travel and push it a bit further, there is another detent which puts it in max cool or max heat. Make sure you feel the click to test the modes.
Old Mar 9, 2008 | 07:32 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
yeah mine to it is normal
Old Mar 13, 2008 | 02:41 PM
AMGDave's Avatar
300D, 500E, E420
The airflow speed will fluctuate based on vehicle speed, but not throttle position. At higher speeds, you'll get a little more airflow. And you'll notice more airflow with the windows open, or sunroof open. If throttle position affects anything, you might have a vacuum leak somewhere....
