300E Idle Mix ok, but when revved goes off the scale to rich.
This is a 1986 300E, 117KMi. I've had this car for about 4 years now, and this is my first serious attempt to adjust the fuel mixture since the missing o2 sensor was reinstalled.
I was able to successfully adjust the idle mixture for close to 0 mA (+/- ~2mA) at the EHA, and very close to 50% duty cycle. But when I rev up the engine to check if it maintains the mixture at 2000 rpm, the EHA current pegs to -10mA in a matter of about 8-10 seconds (the controller is obviously kicking in full-tilt trying to lean the mixture). At that point the o2 sensor reads .94V (very rich), which also confirms the overly rich condition. Also, duty cycle goes down to 20%. Once the engine is allowed to go back to idle, after a few minutes mixture will go back to normal, and the system will get back to closed-loop mode (o2 sensor reads between 0.3 and 0.7V), Duty-cycle goes to 55-60%, EHA current stays within +/- 2mA. BTW, if I disconnect the EHA with engine at 2000 rpm's there is no appreciable change in the mixture. Nor if disconnected at idle because its already set close to 0mA, so basically its having minimum intervention at that point. Adjustment was done with engine at operating temp (~82 C), at idle, no A/C. Water temp sensor measured 355-ohm at said temp, so it is within the target zone, and both sides to ground (its a 2-pin unit) reading the same resistance. Performed the usual static tests before commencing the mixture adjust (engine off, ignition on): - Controller: Initial duty-cycle indicates 70% (standard 49 state controller, status ok). - Iddle contact: Slightly deflected the airflow plate, duty-cycle dropped to 10%, as it should. - Full load contact: Open throttle completely, duty cycle went to 20%, as expected. - EHA coil measures 19-ohm (within spec). - EHA current with engine off: 20mA. Also, in preparation for today's work, last night I stayed up until 4am reading treads in this and other forums regarding the mixture adjustment procedure, and also the magical "1/4 turn CW at the EHA". The o2 sensor was just installed a few weeks back, and seems to be functioning correctly as I've monitored the output voltage, responds quickly to changes in mixute, and voltage readings coincide with what the duty cycle is also reporting, and what the EHA is trying to accomplish (aprox. voltage range between 0.3 and 0.7V when system is operating closed-loop, but only at idle). When engine is revved to about 2000 rpm o2 sensor reading pegs to 0.94~95V (full rich mixture). I don't have a fuel pressure measuring gauge, so no idea what the upper and lower chambers are running at. When I took off the EHA there was obvious tampering on the brass cover, so previous owner was obviously at it. Tried rotating the 2mm hex base mixture screw, first both ways a 1/4 turn. CCW rotation would cause engine not starting, CW rotation by the same amount past the original position made no difference to the initial condition, besides that I had to slightly readjust the 3mm mixture screw on the air intake tower to lean out the mixture in order to compensate and get back to 0mA on the EHA and about 50-60% duty-cycle. Further CW turns, some made in 1/8 and some of 1/4 turn increases did nothing to change the situation. On every occasion I just readjusted the mixture screw and got back the proper idle mixture ratio and closed loop mode. But as soon as the engine was revved up to 2000rpm the EHA would again peg to -10mA in a matter of about 10 seconds, and then return back down close to 0mA after a few minutes. Something is letting a lot of fuel into the system past idle. Since I disconnected the EHA and it made no difference, I would think that the controller and its sensors could be excluded. I checked bellow the airflow plate after engine shut-off for any signs of fuel leaks, and it was bone dry, so this is probably not a leaking o-ring problem. My main suspect now would be either that the chamber pressure differential of the fuel distributor (FD) is way off, and might be causing the rich condition only when engine rpm's are brought up. Not sure if this scenario is possible, I'm only familiar with the innards of the FD in a general way. My other suspect would be the FD itself is malfunctioning, or maybe its just the EHA that is bad? Wish I had a spare to perform that test. Probably will order one next week, hopefully someone on ebay will have one at a decent price. Will also try to borrow a fuel press gauge from a mechanic and check the differential pressure setting. Any comments and suggestions, or additional tests anyone would like me to perform, will be very welcomed. Thanks for reading all this. |
The EHA could be designed to "fail in place", that is, when power is disconnected it does not move either direction. If that is the case, it would not change the mixture when disconnected. I'm not sure how to check it.
did you check the temp sensor that controls the EHA?
Originally Posted by YNVDIZW124
(Post 2723765)
If you mean the engine coolant temp sensor, yes. That was my first suspect. It measured 355-ohm at 82c, so it is within the target zone, and both sides to ground (its a 2-pin unit) reading the same resistance. I was just now looking at the KE injection diagram and noticed the "Regeneration valve" that is connected between the fuel tank charcoal filter, and throttle body. I wonder if there might be any way it could somehow be sucking some fuel fumes through there that would upset off-idle mixture? |
not sure if this is useful to you or not....
http://www.humanspeakers.com/audi/tuning-cise.htm |
Originally Posted by shdoug
(Post 2723683)
Its basically a variable fuel valve, so one would have to feed some test fluid into it and measure the output on the other side while varying the control voltage. Not so easy to set up. Thanks. |
Originally Posted by crr1612
(Post 2723783)
(Post 2723783)
http://www.humanspeakers.com/audi/tuning-cise.htm "An air leak will throw everything off at idle, you will adjust for it, but it will be off by different amounts at other rpms and loads." |
Idle control valve hoses are not cracked right? Also there is a little O-ring under the fuel distributor that may start to leak after some years. I would check the injectors for any leaks on the seals. I figured out all my fuel injection problems by changing the temp sensor ( black 2 posts by the 6th cyclinder)and changing my injector seals. I also replaced the hoses from the idle control valve since they cracked.
(Post 2723854)
(Post 2723854)
(Post 2723854)
(Post 2723854)
(Post 2723854)
They are pretty hard to get to but they usually crack and split open at the ends. They shouldn't be too hard but feel like your breather hose but a little softer. I keep thinking your EHA valve is bad. It should be regulating the fuel going to the fuel distributor and since it's been messed with before and it's probably not working since it doesn't make a difference when disconnected. When the fuel distributor goes bad your engine will stall and run like crap unless you make the mixture really rich and adjust the throttle position sensor to keep it running. The plunger thing in the middle of the fuel distributor shouldn't be lose like when you press it down it should have some resistance or come back out slowly.
Sorry I don't get into specifics of duty cycles, ohm resitance, or air volume. I'm not good at explaning stuff but i know how to fix it. I take my car to a friend and adjust the fuel mixture before doing the smog to put the HC and NOx within specs. I run my car now a little lean and drive slower to save on gas. I still pass smog on a 22 year old car so i think im in good shape. I think i have a fuel distributor and eha in stock but i have to look at my parts garage. ( I have a metal shack full of spare parts ) or you can get the fuel distributor and eha here.. http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW |
(Post 2724123)
(Post 2724123)
What I'm worried about is the base mixture setting screw on the back of the EHA, which as I said had obvious signs of tampering, but then again it is also possible it was actually set right by someone knowledgeable. This 2mm hex screw basically sets the pressure differential between the upper and lower fuel distributor chambers. Factory says it should be set to 0.4 Bar. Many top mechanics recommend to set it to 0.45 bar on high mileage cars as it compensates for any small unmetered air leaks due to wear and tear, and will make the car run much better (that is usually known as the "1/4 turn miracle screw"). Will try to borrow another known-good EHA, or order one, just to make sure this one is not bad, and the other EHA might also have the base mixture setting screw closer to the correct position for sure, so I would actually be performing two tests at once. I suspect that maybe in my case the differential pressure is simply so out of spec that it might be causing the off-idle rich mixture problem. But again, I'm not sure this is possible to happen in this way. I did try reseting it to both leaner and richer setting without any effect other then the car would not start when I leaned it out too far. Problem is I don't have a fuel pressure gauge to check the FD chamber pressures, but will try and borrow one next week and some some tweaking.
(Post 2724123)
(Post 2724123)
or you can get the fuel distributor and eha here.. http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW Is this your own ebay auction, or of a known recommended seller? Thanks again for the input. Don't worry about not using much of the technical terms, most of them are also new to me. As long as there are ideas and useful info to share, the important thing is being able to pass them on. :y |
Maybe you should set the trim screw so that it is as lean as it can be at idle, with the EHA modulating to full rich position just barely keeping the mixture rich enough. Then it will have more room to modulate towards lean at part throttle.
Or, set it so it maintains proper mixture at part throttle and see how it does at idle. I would think a lean idle would not be a bad thing as long as it doesn't stall or idle roughly. |
The one that goes under the fuel distributor area looks like a bi***h to get to. Did you have to disassemble much stuff in order to get the new hoses installed? So you mean to compensate a car would have to run very rich at idle, or overall too rich? If so it sounds somewhat similar to my problem. The airflow plate has some resistance when pushed down, and returns up immediately when released. Read this...this may help... http://www.mercedesshop.com/shopforu...+sensor&page=3 Is this your own ebay auction, or of a known recommended seller? I will take my voltmeter out and test the settings of my EHA and O2 sensor ... |
(Post 2724392)
Or, set it so it maintains proper mixture at part throttle and see how it does at idle. I would think a lean idle would not be a bad thing as long as it doesn't stall or idle roughly. Thanks anyway, appreciate your input. |
(Post 2724505)
I had to remove the fuel pressure regulator to be able to pull it out. The rubber shouldn't be too hard because even if it's not damaged at the ends the hard plastic could cause an air leak by not maintaning a tight seal.
Well i wouldn't remove it unless i have a replacement because you will damage it when removing it. Like i said you will need to remove the fuel pressure regulator, un bolt the wire harness and try to make as much space for your hand to reach and be able to pull it off.
No, certainly no intention on removing those hoses until I get the replacements, maybe just a closer inspection if there is an easy way to get to the difficult places without having to disassemble too much stuff.
I just wanted to know if you had to remove anything to get to the OTHER end, not the one under the FPR. :) |
You mean the one by the cold start valve?
(Post 2724610)
(Post 2724610)
Originally Posted by azurite300e
(Post 2724506)
...this would not exactly the right way of trying to fix the problem by covering up the symptoms. I much rather want to get it fixed and working right for good.
:topic: [Sorry] It sounds to me like the EHA is just not doing anything. The coil may read correctly but mechanically, who knows? I like your idea of replacing it. |
(Post 2726758)
What? Masking symptoms is not a solution? Tell that to the FDA who allows thousands of drugs to be prescribed that do just that, if anything at all.
:topic: [Sorry]
(Post 2726758)
But... in any case if you are reaching your conclusion because there is no change in mixture when I disconnect it at idle, remember that it is at almost zero current, or minimum compensation, when the system is operating closed loop (idle), that is why there isn't any change when it is disconnected. |
o did you have a hard time getting the hose installed on that end? |
