help dead car!
Old Jul 11, 2008 | 01:54 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
Exclamation help dead car!
so i pulled into a parking spot today, ran into a convenience store, came out. car wont start. i figured out the problem, the throttle body doesnt appear to be opening. i can get the car to start if i manually open the body to let air in then floor it. then it dies when i take my foot off. is my throttle body dead? is the thottle body opened mechanically or electronically? pulling on the throttle cable doesnt seem to open it. and when i floor it the body opens up a little bit. i suppose that explains my crappy gas mileage recently, im prolly running rich from a dying throttle body. please help! i cant leave my car in that spot for much longer
Old Jul 11, 2008 | 10:34 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
If you have ASD, (I can't remember if that's what it's called, but it controls the slip ) then it has an electronic throttle actuator. If not, it's mechanical. Most likely yours is electronic if it doesn't open when you touch the accelerator. I'm not sure how those worked on the pre '93.
Old Jul 11, 2008 | 11:59 PM
crr1612's Avatar
well i got the car home. had 5 friends push it out of a spot. get it onto a main road and attempt my way. failed a few times. then someone had the idea of holding it opening with taped quarters. it worked, then i had to drop it into drive at like 4000rpm either way the car is home now i need to figure out why my throttle body is messed up.
Old Jul 12, 2008 | 12:02 AM
crr1612's Avatar
by the way, i dont think its ASD. a friend of mine who was trying to figure out the problem said the throttle body feels like its vacuum operated tho. if thats true...then vacuum leak maybe?
Old Jul 12, 2008 | 09:11 PM
YNVDIZW124's Avatar
lots of cars
Your fuel distributor plunger is bad....
Old Jul 13, 2008 | 09:45 PM
shdoug's Avatar
Are you talking about the fuel distributor plunger (air flow sensor) or the throttle plate (butterfly) that won't open? If the throttle plate won't open that's the throttle actuator associated with the ASD control. Otherwise, fuel distributor problem.
Old Jul 20, 2008 | 03:01 PM
crr1612's Avatar
sorry bout the long time to respond. the plate(butterfly) is not opening till i give the car a lot of gas and then it opens a little
Old Jul 23, 2008 | 12:23 PM
crr1612's Avatar
MAS?
