ABS light on 80 mph speed
my 1992 300e, abs lights lights up when i hit 70-80 mph, but when using the car on the side streets, nothing come up?
any possible suggestion ? like why is it lighting up with it reach a certain speed
THANKS !!!!
If all checks out so far then remove the front sensors and clean the abs ring and retry.
If it happens again, you can actually replicate it by positioning the wheel in a position. Hold it there and watch as it stays on, then turn the wheel and it will turn off again.
Unless you want to take off the steering column, I wouldn't worry about it
thanks again !!!!
