w124 shuts off
There is a way to open the idle valve with the stop adj. but I would not suggest that for someone that has never done it. Its not technically difficult but the brass screw can strip really easily. It has to be heated up to get the thread locker to release.
Also something that happens not to often is the a/c compressor can be worn out and have to much load. This is pretty easy to diag. First if the a/c is off then it does not happen. and then just grab hold of the clutch and if it is pretty hard to turn then the compressor needs repl.
The Parts Bin.
Kevin
