Tumbler gone?
Old 06-12-2009, 11:50 AM
ds190's Avatar
300TE, 300CE
Just take your bent wire tool, press it in to the holes at about 2 o'clock and 7 o'clock in the opening in the steering lock assembly just as if your were guiding it in from "position 1", and the cover will release.
After all, that's actually how the tumbler is held in, by the ignition lock cover.
Old 06-12-2009, 01:50 PM
ps2cho's Avatar
E
Managed to get it earlier yesterday. It seems I was having a problem because when the tumbler is in, it pushes the release down easy, but without it in, I had to bend the wire more and get it at a strange angle. Phew!!
Thanks!
Old 06-15-2009, 02:54 AM
pifcat2's Avatar
300TE / 300E / 300CE
Originally Posted by ps2cho
Oh no I think I may have just messed up big time....
I got my lock cover and I couldn't tell which way the right orientation was, so without the tumbler in, I pushed it up against the lock cylinder and it seems to have "clicked" in place and won't come out.
Have I just screwed this up or can I release the lock cover without the tumbler in?
Can't believe this
You may have to bend it but the U tool should work as the two prongs go down the slots on the tumbler to push the cover release springs. Only one prong pushes on the spring that holds the tumbler.
Quick Reply: Tumbler gone?
