| KOOLY2 |
Mar 6, 2003 04:10 PM |
Coolant System Leak, it's not a hose!
On my 400E the coolant is leaking out at a fairly fast rate, about 1 to 2 days. This morning I jacked the car up to find where the leak is. After pouring several liters of water in the system it soon started to leak, so then I got under the car and pinpointed the leak. It is leaking out of a small black plastic box located under the crankshaft pulley. There is a 1/2" diameter hose that connects it to the water pump. The box itself though has several slits in it to let the water out. Puzzled I popped in my MB service manual CD and found a PDF file that had some information on it. It said that the hose and tank are the coolant drain line and reservoir. I does not make sense to me, I figure that there must be some valve either in the reservoir or just before the small hose that might be ruined. If anyone knows of a possible cause please HELP!
