Used Bosch Headlights Euro Style FS!
I bought new headlights and so these old ones that were on the car are now for sale. Easy upgrade for those with the old US spec looking lights without having to pay double the price for new ones! I am looking to sell them for $100 + shipping.
They both work fine, but there are a few notes.
Left (Drivers) Side:
Uses the 4 pin connector so you can use the stock US-spec pins!
The clip on the headlight adjustment broke, but it is glued together now and can adjust back and forth and works fine. (this is the reason we had to get new headlights because we bought HID's and the ballast would keep pushing the headlight too far up so it kept aiming high. However, with a regular bulb it shouldn't be a problem at all).
Right (Passenger) Side:
Has a small rock chip that punctured the glass, but it is a small hole and I have never had any trouble with it fogging up, condensation, or anything.
The side clips broke off, but you can still install them.
Uses the 6 pin connector so you will have to buy a 6-pin connector to replace the stock 4 pin if you dont already have one. (dont ask me why its different, i have no idea.)
1993 400E, 1994 E420, 2000 SL500, 2014 C250
Well neighbor, I'd like to check out your hid's! I'd be all over these headlights if euro-spec headlights had the little wiper.
correct. if your car already has the lower wiper panel, you can just leave them on and change the headlights. I can show you the HID's I have and the headlights since you're close by. Just shoot me a PM
98 grand prix gtp/94 mb s320
what is this ??
sooooo........where can i get a set of headlights that have a 4pin connection?? mine is cracked and would be great if i could find adapters or a set of 4 pin connector headlights----i bought a set and there 5 pin....i need some knowledge
you need to buy the little 6-pin plastic adapters and re-wire the plug from the 4 pin to work with the 6-pin. if you do a search you will find info on the forum or even just google it.
yessss !!!!!
zedstyle------thank soooooo much i appreciate it just when i thought all hope is lost and **** someone replies and givez me some knowledge i really appreciate it----and im going to look up the connectors nowwwww THANK YOU for your help
