Headlight Wiper install on W124
Hi Everyone-
Is it possible to install headlight wipers on a 1994 Mercedes E320 that does not have them currently? I've always loved the look and wouldn't mind taking on a project. Even if it's expensive, I'm still interested. Thanks! |
Yes, you need a pump that attaches to the washer fluid reservoir, the wiper assmeblies, the washer fluid tubing to both lights and trim panels for the 94-95 with the wiper holes and grommets.
There may be more to it though, as far as connecting it all to the headlight switch and washer stalk on the steering column.. |
I just removed both motors from my car (1994 E420, both work fine). One of the wipers is broken, the other is good. I also have trim plates with the holes. Contact me if interested, can sell it all.
the headlight washer/wiper unit plugs into a 4-pin plug (only 3 pins in it) that comes from the headlight wiring harness, so if you don't have those, as zorro said, you will probably need to do some wiring to make them functional.
currently, mine are not :D |
Hi there!
Actually I am goind to do the same, and found this photos about this http://www.oldmerc.net/installing-he...w124-w201.html |
