'94 E320 Idle Control Valve location.
Old Mar 16, 2010 | 11:58 PM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Does anybody know where the ICV located on a '94 E320? While idling, every now and then the RPMs surge up to about 1500. I replaced the oxygen sensor, it did not fix the problem. I want to check the ICV, but can't find it.
Old Mar 17, 2010 | 12:17 AM
FastE550's Avatar
2007 E550, 2002 C32,2004 S430,2001 E320
w124 E320
Its on the intake maniold its plastic part # 000-140-04-31
Old Mar 17, 2010 | 12:24 PM
Arnie's Avatar
I think that part is called Exhaust Resonance Flap Valve. It can't be the same thing, or can it?
Attached Thumbnails '94 E320 Idle Control Valve location.-000-20140-2004-2031.jpg
Old Mar 19, 2010 | 01:20 AM
Arnie's Avatar
Okay, those of you that have occasional idle surges issues: In my case it was an air flow meter. During the last three days I replaced oxygen sensor, it didn't fix it, then sparkplugs, then the exhaust resonance valve (see above), and finally the airflow meter. The surges were occasionally occuring until the air flow meter replacement, and for the last day and half - no problem.
