300E Turbo LPG Project
mods included head work, mechanical tappet mod, cam change 3.2 crank ect, oil squirter's would have been available, so they would have been daft not to use them.
this is holding up the six speed swap, as i dont want to have to have two prop shafts made, so need to do both at once.
I've got the 3.65 diff I believe with the standard 5 speed manual, and my gear ratios aren't bad.
60-100-150-220-?
Never took it past 220, but 5th isn't overdrive. I'm thinking it'll get to 260, and not more.
Which isn't really bad. You get oomph in every gear that way, no?
I intend to get the dogleg tranny this summer, which might have shorter ratios so at that point I'll definitely need to upgrade my differential.
Now way anyone parts these cars either as they are collectors now. I'd be better off with a LSD from another make from down here that's for sure. Some use Nissan GT/GTR diffs but the Ford XRT6 diff is more than enough. Again though, hard to get & expensive plus, prolly need modding with axles etc too. Like anything else custom for the Merc. Who knows
its not the amercan equiv of an overdrive but the ratio is less than 1.0:1 and more like 0.87:1
and the fifth gear is 1:1
the 265 is available with od, but is not the same box as the 16v one.
That was a tank of a tranny.
I doubt it fits our M104's, but if it does I'm doing it TOMORROW. :P
Anyway, finally realising the guy @ original workshop is correct on one important matter.......the .63 A/R housing will be a maniac for the street. Dyno figures aside (VE ie: top end performance/rwhp), the thing will be a wheelspin junkie
Obviously the .82 A/R housing will = greater power & allow boost to come on more gradual (linear) & solve the wheelspin issue but the trade-off will be 500rpm added to spooltime
What does that exactly mean? If I use the smaller snail, I will have to watch exiting any remotely tight corners, especially in the wet ohhhh FUN
Flipside? What fun this bugger will be once I get used to it hehe
...........er.......gettin off this ergonomic chair as I really have a sore *** & back & my legs are now totally numb
I've driven both types of turbocharged cars, high spool and quick spool, and I preferred quick. However, the 300E is more powerful than the Evo at low RPMs, so I have no idea how it would compare on the road.
Best turbo charged car I've driven has got to be the 335i. You've got alot of torque to work with from 1800 rpms.
I guess it depends on what you want from the car.
It's a difficult call. I know the .82 A/R turbine housing will come on easier/later but the main problem I see with the GT35R is the large .70 A/R comp housing. Quite a mismatch with the .63 A/R turbine housing if you consider the huge air flow capabilities of the comp housing. The smaller GT series turbos have the .60 A/R comp housings.
The engine will probably produce about 10%+ more torque then horsepower.
The only thing it doesn't list is a VR sensor needed to read the trigger wheel but everything else is there. Man oh man! For members that like the MS stuff, you can now get the MS III with MS3X v3.57 expansion card fully assembled for direct fire sequential capabilities & cylinder by cylinder fuel/ignition control? Some may have but I am blown away because this means the workshop can use it instead of the expensive stand alone's such as Microtech spark only ($980AUS) or the top notch Haltech Platinum Sport 2000 stand alone, like $2k without harness
Fark off
I need to exhaust why I can't simply go wasted spark & use the Ford EDIS-6 system for example. It's due to it's incompatibility issues my workshop has experienced with LPG in the past. He's won't use it again.
Haltech tried to convince him to go with the platinum ECU because they had great success with a Beema you see? Hmmmm. Good salesmanship.
So, this is why I took the reigns & did some searching & think I won out ey? When doing custom work on these cars, you have to source **** yourself man
I just spoke with the engineer responsible for signing his life away on the VASS cert needed for VicRoads to register car. In other words, the guy who, along with myself, bares full responsibility for the build passing all present EPA guidelines & foreseeable hassles by the pigs up ahead. Anyone wishing to boost a vehicle mode that has no factory turbo option must adhere by the ADR testing. Only if a turbo kit is certified to be ADR compliant, by the manufacturer, is it except for the test!
The no-nonsense approach to this is to do the mods to my hearts content then show up n@ VIPAC for it's ADR 2700 (pre-88) test @ $1600 (up 100 since last enquired few months back haha....) If it passes the stringent testing over 2 days, fine! Fails? back to shop, more tuning etc then, back to VIPAC to shell out another another $1600 each time till it passes.
NOTE: If it had been a pre-unleaded (pre 86') it would be except from the ADR emissions testing
Meanwhile, engineer will be contacting VicRoads, within next few days haha, to discuss if I can get away with $600 IM600 test, used for testing existing modified cars. Hmmmmm, doubt this will help & it will not prevent EPA finding something in the future if a test is called for by the fuzz!
Just about ready to throw the towel in with boosting
I am not prepared to pay over $2k to regulatory personnel for them to deem my car "legal" concerning emissions whilst poor architecture accounts for 40% of the world's greenhouse gases & cow farts around 25%. So, instead of penalising motorists for the little they contribute in order to get to their employment & enjoy a little hp, let them ADR schedule fauna & tax all meat-eaters
Farkheads! Can a mod or admin pls close this thread. If/when I do boost the car in the future, I will start a new thread & keep it short
Thanks to all who inputted valuable info & I'm sure folk got something outta reading posts on this thread. At the very least it informed Aussie "tuners" the facts concerning the ADR requirements that govern the EPA body & tie the hands of Engineers & tuners alike. Remember, although most modified cars are illegal in many aspects of build, if you do get searched/defected, you will face the EPA scrutiny & fines are staggering! Good luck
Tim!
As long as it remains dedicated LPG I can virtually do what I like! He just wants the intake manifold stock other than the mixer set up. 10mm clearances all around whole car. Upgraded brakes (already have the set I purchased). Suspension not too modified. Wella. He sees the car when it's finished & writes the VASS cert
Needless to say I phoned workshop immediately & told him. Also, will be 'bottom mounting' turbo on manifold. Will be most prolly using a Haltech aftermarket ECU so I can run direct fire coil packs to protect against detonation. I know the weak links of the stock engine are the rings/landings & HG.
Also, I am looking @ below mounting the turbo on manifold now & keeping the .63 A/R rear so, heaven help me in the wet
