No headlights
Old Mar 17, 2011 | 05:57 PM
heoliver@cox.ne's Avatar
No headlights
My 1995 E-320 has no headlights. Changed blubs, checked fuses no light. Neither high nor low beams. Think it may be the switch. How do you remove the switch ?
Old Mar 17, 2011 | 08:12 PM
ZedStyle's Avatar
Youngtimer
can you turn on the left-only or right-only side markers with the switch, or is that also not working? If those are not working, then you know for sure it must be the switch...
aren;t you the guy whose headlight knob was broken? What did you do to fix/resolve that?
Old Mar 17, 2011 | 11:01 PM
That was someone else. Side lights and road lights work. But no headlights. Where do I look next? Any relays ?
Old Mar 18, 2011 | 10:07 AM
Shoomakan's Avatar
2006 C55 AMG 6 speed
If you hold the highbeam switch backwards, does it light up?
I had the same problem, it was the big relay/switch/thing that the knob is installed on.
